valve dimensions
Old Mar 31, 2007 | 09:09 PM
neversummer's Avatar
valve dimensions
I feel like this is a stupid questions - BUT
is the reference size of the valve the diameter of the bottom of the valve? And if I were to hold the stock valve and an oversized valve butt to butt would I see the difference?
Thanks.
Old Mar 31, 2007 | 09:55 PM
seawolf06's Avatar
Explain oversized valve.
The numbers that most people post about aftermarket valves are the bowl diameter, I guess that's what it's called. (2.0, 2.01, 1.6)
The stem diameter stays the same. 11/32" IIRC.
Old Mar 31, 2007 | 11:50 PM
MachinistOne's Avatar
Opps - wrong forum...lol - gave you powerstroke valve sizing
Yes - you will visibly see the difference in an oversize valve. The stock valve size is 1.94"/1.50" with 11/32" stem
Old Apr 1, 2007 | 04:36 AM
Thanks. That's what I thought. I was told I had oversized valves. But on pulling the heads and inspecting with stock valves, they were the same diameter.
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
94Form
Jul 17, 2015 10:56 PM
