valve dimensions
Old 03-31-2007, 09:09 PM
neversummer's Avatar
valve dimensions
I feel like this is a stupid questions - BUT
is the reference size of the valve the diameter of the bottom of the valve? And if I were to hold the stock valve and an oversized valve butt to butt would I see the difference?
Thanks.
neversummer is offline
Old 03-31-2007, 09:55 PM
seawolf06's Avatar
Explain oversized valve.
The numbers that most people post about aftermarket valves are the bowl diameter, I guess that's what it's called. (2.0, 2.01, 1.6)
The stem diameter stays the same. 11/32" IIRC.
seawolf06 is offline
Old 03-31-2007, 11:50 PM
MachinistOne's Avatar
Opps - wrong forum...lol - gave you powerstroke valve sizing
Yes - you will visibly see the difference in an oversize valve. The stock valve size is 1.94"/1.50" with 11/32" stem
MachinistOne is offline
Old 04-01-2007, 04:36 AM
Thanks. That's what I thought. I was told I had oversized valves. But on pulling the heads and inspecting with stock valves, they were the same diameter.
14
08-11-2015 12:03 PM
96SilverRam
08-09-2015 04:15 PM
RX Speed Works
07-24-2015 02:25 PM
HectorM52
Parts Wanted
07-19-2015 08:55 PM
94Form
07-17-2015 10:56 PM
Quick Reply: valve dimensions
