Pin Drive or spline drive??
Old Feb 2, 2007 | 05:57 PM
DougsZ28Camaro's Avatar
I just recently purchased a Lt1 383 stroker with about 450+ HP. My question is do i need the pin drive distrubtor or the spline drive? My old engine was a stock Lt1. any help would be great. Thanks
Old Feb 2, 2007 | 06:00 PM
OBE1 95Z28's Avatar
It depends on what style cam was used as the opti is driven off the end of the camshaft. LT1's had both styles, 93-94 were spline driven, 95-97 were pin driven.
Old Feb 2, 2007 | 06:08 PM
ok well mine was a 94. So that means i would need the spline drive then correct?
Old Feb 2, 2007 | 07:39 PM
OBE1 95Z28's Avatar
If you want to reuse your 1994 opti, then you need a cam with the spline drive. What cam type was installed in the 383?
Old Feb 2, 2007 | 07:42 PM
OBE1 95Z28's Avatar
Here's a link to a good write-up explaining some of the differences:
http://para.noid.org/~muttvette/opti.html
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Cam's maro
Jan 30, 2015 09:21 PM
importkiller94
Jan 17, 2015 09:03 PM
