which of these will help the lt1 out more?
i am getting a tune from mad z28
i am getting the vats disabled so i need to pick 2 other things to do which should i get
$75 -- The "Saver" Package includes any 3 items from the following: Remove Skip Shift, Adjust Rev Limiter, Adjust Fan Kick On Temperature, Adjust Speed Limiter, Disable Any Code, Disable VATS, Adjust for different tire/gear size, knock retard desensitizing. This service does not include power tuning. Please add a core charge (Item #8) if you would like to exchange PCMs.
Personally, I would put up the extra money and get the full package that includes the power tuning. If you are set on the "saver package" though, I would definitely go with the coolant fan on/off temp adjustment and since you have headers, I would maybe consider the knock retard desensitizing.
I second it..
I second it, his service sucks. of course I have h/c and other mods. to make this story short his tune was way too lean, he would not make any changes to it. wanted me to buy the moates setup to make the changes myself. decided to go with a live tune to get mine straight. but with your minor mods a mail order tune prob. would be the way to go. but I would def. look at pcmforless as another option.
i also had a bad experience with MadZ28, didn't disable skip shift, set up WAY to lean, didn't answer any questions when i called, told me they tuned it all perfectly when i was looking at the sheet and my shifter and it would only go 1-4-5-6-R..?? so next time i get a tune its gonna be PCMforless
-Chris
-Chris
Although I have seen an increase in complaints about slow service in recent months.
You could always just contact him and tell him that you really only want the VATs disabled. There was a time where I only wanted to have one thing done to my PCM and he was willing to do it for a smaller cost.
oldschool
Feb 9, 2016 09:21 PM
