which of these will help the lt1 out more?
Old Nov 22, 2006 | 12:57 PM
jamilz28's Avatar
i am getting a tune from mad z28
i am getting the vats disabled so i need to pick 2 other things to do which should i get
$75 -- The "Saver" Package includes any 3 items from the following: Remove Skip Shift, Adjust Rev Limiter, Adjust Fan Kick On Temperature, Adjust Speed Limiter, Disable Any Code, Disable VATS, Adjust for different tire/gear size, knock retard desensitizing. This service does not include power tuning. Please add a core charge (Item #8) if you would like to exchange PCMs.
Old Nov 22, 2006 | 01:25 PM
dre2013's Avatar
well since you are a4 u dont need to worry about the skipshift, so id have the shift points/rev limiter changed, and fan kick on temp
Old Nov 22, 2006 | 01:30 PM
69gto96z's Avatar
I used MadZ28 and his customer service sucks. If I could do it over again I would have used PCM4Less.
Old Nov 22, 2006 | 01:33 PM
2000GTP's Avatar
Personally, I would put up the extra money and get the full package that includes the power tuning. If you are set on the "saver package" though, I would definitely go with the coolant fan on/off temp adjustment and since you have headers, I would maybe consider the knock retard desensitizing.
Old Nov 22, 2006 | 01:43 PM
Z-RATED94's Avatar
And to add to that, he did a fine job when setting up mine for a H/C swap that involved many other modifications.
Old Nov 22, 2006 | 02:24 PM
93yellowta's Avatar
I second it..
I second it, his service sucks. of course I have h/c and other mods. to make this story short his tune was way too lean, he would not make any changes to it. wanted me to buy the moates setup to make the changes myself. decided to go with a live tune to get mine straight. but with your minor mods a mail order tune prob. would be the way to go. but I would def. look at pcmforless as another option.
Old Nov 22, 2006 | 03:09 PM
rickreeves1's Avatar
I can't comment on the other tuners but I am very happy with the PCMFORLESS tune.
Old Nov 22, 2006 | 03:55 PM
Bersaglieri's Avatar
Madwolf has always treated me and folks I know very well.
-Dustin-
Old Nov 22, 2006 | 04:13 PM
StephenDeli22's Avatar
He was a little bit slow getting back to my emails, but his work spoke for himself and my tune is a great deal better over stock.
Old Nov 22, 2006 | 04:29 PM
n2ceptor's Avatar
Atleast for my 93Z, it came with the optional "Z" rated tires and has not speed limiter from the factory..
Old Nov 22, 2006 | 04:32 PM
93black-ta's Avatar
id deffinately save for the power tuning. if you cant figure out what other options you would like it probably means they are pretty much useless to you.
Old Nov 23, 2006 | 12:49 AM
silentsprintero's Avatar
i also had a bad experience with MadZ28, didn't disable skip shift, set up WAY to lean, didn't answer any questions when i called, told me they tuned it all perfectly when i was looking at the sheet and my shifter and it would only go 1-4-5-6-R..?? so next time i get a tune its gonna be PCMforless
-Chris
Old Nov 23, 2006 | 12:52 AM
Dave1980's Avatar
It just seems really crummy that you have to pick three things. I just used PCMforless and told them what i want. There was no pick three, but only a full mail order tune.
Old Nov 23, 2006 | 06:00 AM
sbs's Avatar
sbs
Fans for sure.
Although I have seen an increase in complaints about slow service in recent months.
You're right it's crummy... that they don't offer a cheaper service for people who just need a couple of simple things done.
Old Nov 23, 2006 | 08:21 AM
2000GTP's Avatar
You could always just contact him and tell him that you really only want the VATs disabled. There was a time where I only wanted to have one thing done to my PCM and he was willing to do it for a smaller cost.
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
