Typical oil pressure 3.4
Old Apr 30, 2005 | 10:28 PM
megabass's Avatar
Just wondering what is normal. Mine seemed a little low the other day.
Old Apr 30, 2005 | 10:38 PM
deadmeat2004's Avatar
Re: Typical oil pressure 3.4
mine is low a lot.. it varies all the time. depends if im at idle or drinving
Old May 1, 2005 | 06:00 PM
MarcR94v6's Avatar
Mines always pretty high. Full 80 when I'm driving, 70-75 or so when I'm idle.
Old May 1, 2005 | 08:41 PM
megabass's Avatar
That's much higer than mine. Mine is maybe 60 on start-up, 40 when driving and 30 at idle.
Old May 1, 2005 | 09:05 PM
garymoore's Avatar
that a alot bigger then mine my is 40 at frist then it goes to 5
Old May 1, 2005 | 10:05 PM
depends on what oil u run... like i said at top it changes all the time. I use mobil 1 5w-30. good sh|t!
Old May 2, 2005 | 02:21 PM
camarobiatch
Guest
Posts: n/a
Mine idles at 45 ish runs at about 70. Using the synthetic also...........
Old May 2, 2005 | 03:57 PM
idles around 8 and runs around 35..
Old May 2, 2005 | 04:40 PM
MarcR94v6's Avatar
Wow, I guess I'm doing good then.
Old May 2, 2005 | 06:36 PM
Feenix's Avatar
in my old 3.4 my oil pressure started dropping a little and I thought something was wrong with the motor, and it ended up being the sending unit. So if your oil pressure dropped a little out of nowhere it may very well be that.
Old May 13, 2005 | 12:35 PM
EKO's Avatar
EKO
I've posted this before, but mine has been idling at about 2psi when it gets hot using M1 10-30, for about 3.5-4 years now. Not that I really care much anymore as the LT1 is coming along, but hey, no serious mechanical problems with it for that amount of time.
Old May 13, 2005 | 01:52 PM
Duke901's Avatar
On my 94 3.4 my oil pressure is 40 driving and under 10 at idle.
Old May 13, 2005 | 06:50 PM
MarcR94v6's Avatar
I'm not sure, but I don't think it should be quite as low as some people have said. You might want to check your oil sensor, it might be broken and not know how much you need/how much is going in, and causing low performance.
HectorM52
Jul 30, 2017 11:46 AM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
transam_388
Mar 15, 2015 11:53 AM
