New kid with over heating problem
Old Feb 22, 2005 | 09:11 AM
BadLilv6maro's Avatar
Unhappy New kid with over heating problem
I bought my first camaro last year, 94' v6 auto, and by summer had minor over heating problems. ive had the freeze plugs replaced multipule times and it still is getting hot, any ideas on how to solve this problem cheap?
Old Feb 22, 2005 | 09:25 AM
JoshMcMadMac's Avatar
Re: New kid with over heating problem
Overheating is typically a problem of the water pump, radiator, coolant, or thermostat. I would recommend checking out the water pump first. If it is alright, then move on to flush the coolant and replace the thermostat. Be sure to use the proper (orange) coolant.
Also, what do you consider "minor overheating problems?"
Old Feb 22, 2005 | 09:49 AM
well ive taken it to some local shops n the answer i got was that the problem is from the previous owner not flushing the system, and that it could continue to over heat or it could stop. friend said manual fan switch could help wat u think?
Old Feb 22, 2005 | 02:29 PM
Answer this so we can determine what exactly you feel the problem is.
Old Feb 22, 2005 | 10:41 PM
it seems like im losing antifreeze but im not seeing any leaks, it possibly could be boiling over, but once i add antifreeze it will go away for acouple of weeks. n when it starts to overheat i notice my heater will stop blowing hot air
Cam's maro
Mar 24, 2015 08:09 PM
kksi
Feb 17, 2015 10:41 PM
Jan 23, 2015 01:13 PM
