99 3.8 fuel pump problem
Old Feb 19, 2005 | 07:50 AM
94blkTA's Avatar
I have a 99 3.8 camaro and fuel randomly doesn't come on at startup. I have replaced it once and it seemed to run fine for a couple of days and then it left me stranded again. I checked the fuse, switched the fuel pump relay with the ac, tried starting with the spare key, and tried to reset the battery and nothing helped. I ordered another fuel pump for it, but before I got it put in it started again and ran fine for another couple days. I hooked the original fuel pump I removed from it directly to a battery and it seemed to work fine. Is the fuel pressure reg. bad, could it be the pcm?
Old Feb 19, 2005 | 04:24 PM
JJayzX's Avatar
Re: 99 3.8 fuel pump problem
Did you try and replace fuel filter it could be clogged.
Old Feb 19, 2005 | 04:50 PM
94blkTA's Avatar
Yeah, I have replaced the fuel filter.
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
