Valve Cover Breather
Old Jan 21, 2004 | 08:10 PM
blazebdb's Avatar
Evening All, my buddy recommended I get a Valve Cover breather to reduce pressure in the engine. He says they have some that just screw in where the oil cap goes...plug and play. Im afraid Ill have oil blowing out of the thing. Is it this easy to prevent a seal leak later....Im all bolt on only...any info is always appreciated..
-Bryan
Old Jan 21, 2004 | 08:16 PM
ibanez6rg's Avatar
I don't think you'll have to worry about oil blowing all over the place.
Old Jan 22, 2004 | 12:44 AM
Seal's Avatar
does it to anything?
what advantages does it offer?
Old Jan 22, 2004 | 01:46 AM
chesee48's Avatar
I dont have one, but i heard that its more of an apperance item then anything else...
Old Jan 22, 2004 | 07:37 AM
Not any advantages to putting a breather on if you are normally aspirated. A search will tell you all you need to know.
Old Jan 22, 2004 | 08:19 AM
Bastardcat's Avatar
I had one for awhile and did not have any oil spitting out anywhere. However, after doing a little research on the subject I removed it since it "opens up" an otherwise closed system. Check here for more info.
Old Jan 22, 2004 | 09:25 AM
dren70's Avatar
From: brunswick ohio, small burb south of cleveland
does anyone know where to get a breather that fits in the stock cover rubber?? i couldn't believe how much oil was coated on my intake when i pulled the throttle body. i disagree with "it wont do anything". power probably not but cleaner intake (no oil vapor) absolutely IMHO.
Old Jan 22, 2004 | 10:49 AM
fuzzyz28's Avatar
I've got one; no problems whatsoever.
Go to the K&N website, measure the diameter of the filler opening, and get one to fit it. That's all I did; looks real good.
Agree though, it's more for looks than anything. If you have a supercharger or something that is seriously going to increase crankcase pressure, it will help reduce that pressure.
for us normal guys, it's basically for looks.
Old Jan 22, 2004 | 12:14 PM
agent z28's Avatar
If you're using a strut tower brace, installing a breather in place of the oil fill cap can result in clearance problems. The Metco breather that Tunderracing sells woundn't clear my Hotchkis bar. I think the braces offered by BMR and Edelbrock might offer more clearance, though.
Old Jan 22, 2004 | 01:18 PM
v7guy's Avatar
i would suggest running a system like a lot of the LS1 guys are with a catch can for the oil, that way you don't have to worry about oil in the intake and you still keep it a closed system
Old Jan 22, 2004 | 09:06 PM
dren70's Avatar
apologies to shoe. i just got home and read my post and it sounded like i was contradicting you. never was intended. sorry in advance before you never answer any of my noobie posts.
Old Jan 23, 2004 | 10:18 AM
blazebdb's Avatar
As always thanks for all the information fellas. I think I will keep it off until I get a bit more HP under the hood. Thank you all for your quick replies!!
Old Jan 25, 2004 | 02:49 PM
darkangel95's Avatar
I have seen this mod on LS1's but how could this be done on our cars?
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
