Please help!!!!!
I just installed a new water pump in my car but i broke the hose that goes from the lower passanger side of the pump to the heater core. It looks like a b***h replace. my question is 3in from were the hose starts there is a metal part of the hose with a spring in it
? The hose broke clean were the rubber and metal meet so can i remove the metal splice in a rubber hose here and be ok for good or ok till i replace the hose do i just need a new hose?
hose with a spring in it ? The hose broke clean were the rubber and metal meet so can i remove the metal splice in a rubber hose here and be ok for good or ok till i replace the hose do i just need a new hose?
I wish I could have just pulled the hose from the valve. Mine is stuck there solid and I dont have a dremmel to crack that metal sleeve open.
Easy job for you. Time to replace all your coolant too. Dont worry its an easy job. Someone here suggested to do away with the valve but I notice the valve its a coolant restrictor and I didnt was all my coolant to rush through my heater here in Hawaii gets hot enough as it is
. Just clamp the new hose to the valve and be done with it. else you will pay over a 100 bucks to replace the complete hose and I heard is a pain in the **** to remove it from the firewall on the passenger side.
Marvin
So this valve is too keep too much colant from flowing into the heater core? So can i safely by-pass this?
Marvin
