Technical service bulletin on stock driveshaft?
Is it true that you can get a free aluminum DS from the dealer if you have the "vibrashaft" problem? Someone told me this can be done. Does your car still have to be within warranty?
As posted above.... a "technical service bulletin" (TSB) is NOT a recall. It is simply a set of instructions to the dealer mechanics, telling them how to fix a recurring problem. If your car was under FACTORY warranty, and you could demonstrate that you had the specific problem addressed in the TSB, they would fix it under warranty. But once your warranty runs out, no more "free".... unless you have a dealer that happens to bend the rules a little.... but I suspect your "3 years of 36,000 mile" warranty is probably deceased.
The whole "warranty" thing is a big joke, since the GM's service to me absolutely blew.
I tried getting one on my 97SS while it was under warranty, but the TSB was only good for 96 and older. I have heard of some on this board who were able to get one, I was just told that my 97 didn't qualify. I still don't know why the 97 wouldn't have the same problem and could never find a resource to tell me if and how the 97 was fixed.
And being such a wuss, I haven't had my car up to a speed to be able to detect any vibes.
I'm running 4.10s with around 350 RWHP, but still don' know if the DS is out of balance.
The TSB was actually only up through 96 because GM supposedly fixed the problem on all 97 cars somehow. I don't remember the specfics, but it seemed like they tried balancing all the 97 shafts, which was one of the reasons for moving to the aluminum driveshafts on the LS1 cars.
Either way, with 4.10s if you had the "vibeshaft" problem you'd notice it at around 65-70 if I remember correctly. I had 4.10s in my 95 and got the replacement aluminum shaft under warranty due to this. For the original poster, if you don't have the vibration problem, I would stick the stock steel unit. As you are out of warranty the TSB won't help you, so if you do have the vibration, do one of the following:
1) get the stock unit balanced at a driveshaft shop
2) get a new steel driveshaft that is balanced
3) get a 1LE aluminum driveshaft (you can find them on Ebay sometimes)
4) get an LS1 aluminum driveshaft
Personally, I'd avoid the aluminum units if you ever plan on making big power or using slicks as they are weaker than the steel units.
ddr698
Jan 31, 2015 10:58 AM
wytblur
Jul 19, 2002 10:26 PM
