1.7 rockers with this cam?
Old Jan 12, 2004 | 12:03 PM
BottleFedZ28's Avatar
XE 230/236 with ported heads.
I don't know how much they milled the heads. I'm guessing 5-10 thousandths.
Can I run 1.7 rockers?
Will I need an AFR Rev kit?
Old Jan 12, 2004 | 02:35 PM
TTT
Old Jan 12, 2004 | 02:54 PM
Fastbird93's Avatar
Well with the 1.7's you'd be looking at .578 intake and .589 lift. If the heads weren't milled too much and you've got the springs to handle the lift, I don't see why it wouldn't work. You will definitely need to check your valvetrain geometry though. Make dang sure you've got the correct length pushrods and check your piston to valve clearance.
Old Jan 13, 2004 | 08:43 AM
How do I check the piston to valve clearance?
Is there a general rule of thumb about how much shorter the pushrods should be?
Old Jan 13, 2004 | 09:01 AM
94_Camaro_LT-1's Avatar
Like this
I beleive summit sells the indicator... As long as you have a hundreth you're golden...
Old Jan 13, 2004 | 09:25 AM
Thanx.
Do you know what the guage is called?
Old Jan 13, 2004 | 02:01 PM
This kit has everything you would need...even the instructional video
Old Jan 13, 2004 | 03:20 PM
Thanx dude.
Old Jan 13, 2004 | 04:32 PM
Not a problem!! GOODLUCK
Old Jan 13, 2004 | 05:35 PM
Gripenfelter's Avatar
Unless he milled a lot off the heads I doubt it will be a problem.
The only thing you should check in the valve train geometry to make sure the rockers are on the center of the stem and not rolling over the edge.
Color the tip of the stem with a felt marker. Run the motor for a minute and then check to see where the rocker sits on top of the stem.
oldschool
Feb 9, 2016 09:21 PM
HarleyZ28
Oct 5, 2015 06:23 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
