Need Help Removing Water Pump Drive From Block...
Hey,
I have my timing cover and intake manifold off, and have been trying to remove the water pump drive assembly from the block so I can run my double roller timing chain, and I havent had it budge yet. I hit it with a hammer, and a punch and hammer, and it doesnt seem to have moved, I have been hitting the back of the assembly from inside the intake, am I missing something
, everyone seems to think it comes out pretty easy..
Thanks,
Brandon
, everyone seems to think it comes out pretty easy..Thanks,
Brandon
lol, is their a retaining plate on the assembly?? All i saw is the drive that sticks out of thetiming cover, a gear its attached to, and the silver end sticking out of the intake manifold, I must be missing something.
Thanks,
Brandon
Thanks,
Brandon
Originally posted by AsianSensation
The retaining plate sits behind the water pump drive so the water pump drive and retaining plate will have to come out together.
Thanks,
Brandon
Remove the 2 torq screw, then *hammer* it out from the lifter valley. The retaining plate and water pump drive will come out together. The retaining plate is *pressed fit* on the water pump drive assembly.
