Need Help Removing Water Pump Drive From Block...
Old Jan 12, 2004 | 07:43 PM
Brandon 95 Z28's Avatar
Hey,
I have my timing cover and intake manifold off, and have been trying to remove the water pump drive assembly from the block so I can run my double roller timing chain, and I havent had it budge yet. I hit it with a hammer, and a punch and hammer, and it doesnt seem to have moved, I have been hitting the back of the assembly from inside the intake, am I missing something , everyone seems to think it comes out pretty easy..
Thanks,
Brandon
Old Jan 12, 2004 | 08:30 PM
AsianSensation's Avatar
I maybe totally out of line, but did you remove the two torq screws that is holding the retaining plate?
Old Jan 12, 2004 | 08:33 PM
lol, is their a retaining plate on the assembly?? All i saw is the drive that sticks out of thetiming cover, a gear its attached to, and the silver end sticking out of the intake manifold, I must be missing something.
Thanks,
Brandon
Old Jan 12, 2004 | 08:48 PM
If you don't have a drop light, it's a valuable tool to have.
Old Jan 12, 2004 | 09:04 PM
rocmemphis's Avatar
Remove the retaining plate first. Then take a socket about the size of the drive bearing and beat on it from behind with a mallet. It will eventually come off.
Old Jan 12, 2004 | 09:17 PM
The retaining plate sits behind the water pump drive so the water pump drive and retaining plate will have to come out together.
Old Jan 12, 2004 | 09:59 PM
So are you saying I dont have to remove any sort of retaining plate before whacking at the bearing through the intake??
Thanks,
Brandon
Old Jan 12, 2004 | 10:03 PM
Remove the 2 torq screw, then *hammer* it out from the lifter valley. The retaining plate and water pump drive will come out together. The retaining plate is *pressed fit* on the water pump drive assembly.
Old Jan 12, 2004 | 10:11 PM
Robert95z's Avatar
Retainer
Old Jan 13, 2004 | 08:21 AM
WS Sick's Avatar
IAs said before , remove the two retainer torx screws and then get the appropriate sized socket and hammer it out, hammering on the socket on the lifter valley side.
HectorM52
Jul 30, 2017 11:46 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
