Wet weather = NO start - HELP!
Symptom:
First, the car would backfire or otherwise run poorly at high RPM (5600- 5900) at WOT until I let off. Only did it every once in a while
After a "soaking" day long rain, my car won't start.
Happened 3 days ago first. Let the car sit for a day (it finally quit raining) and then it started okay, but didn't act quite right for a bit. Maybe partly flooded from before. I put new plug wires in the car
and it seemed fine.
Did it again this morning, it rained all last night.
I've searched on here for wet weather problems and it sounds like it is one of the following:
1) Bad coil
2) Bad coil wire
3) other corroded connections to the Opti
4) Bad opti unit.
But if you throw in the added problem of the high RPM backfiring, which is the most likely problem??
Car is a 95 T/A M6 with 59K.
Any help would be great. Thanks.
.After a "soaking" day long rain, my car won't start.
and it seemed fine. Did it again this morning, it rained all last night.
1) Bad coil
2) Bad coil wire
4) Bad opti unit.
you can check that coil to see if it works. simply unhook the lead power wire to your opti from the coil and hold it to the block and have some one turn it over. if it sparks then it works.
what happend to your car is happens all the time. your opti got wet and might be broken for good. by let it dry for a day or two and see what happens. it may dry and all will be well.
It seems strange that the opti would have picked this period of time to get wet. I have driven the car in all kinds of rain, and it has sat outside for the last 6 months with no problems. Before that it was a garage kept car.
Seems strange that it could get wet while not in motion. The engine looks dry. Even if I put a new opti in, it could still get wet, right? Again, it seems strange that it happened now and never before.
But hey, I'll try anything. Hate driving the beater to work.
I'll try testing the coil when I get a chance. And put the new coil wire on, too. :big grin: Didn't think they had one. Was wondering why I got that "extra" wire!
Thanks to you all for helping.
squarehead
Jan 15, 2015 07:02 PM
[New Jersey] Cure those winter blues with the NJFBOA!!!
njspder
Middle Atlantic
Jan 8, 2015 11:13 AM
AL SS590 M6
Sep 12, 2002 03:23 PM
