how to stop exaust leak
Old Jan 2, 2004 | 01:33 PM
z28marine's Avatar
Well, i installed MAC headers, and used copper gaskets. but, there is still an exaust leak. Both sides have slight leaks around the middle two exaust ports. Ive tried tightening them as much as possible, but they still are leaking...should i try changing the gaskets or what?
Old Jan 2, 2004 | 01:36 PM
SloLt1Z's Avatar
orange high temp rtv will work
Old Jan 2, 2004 | 01:44 PM
jasons93z's Avatar
I agree on the RTV, but its actually RED (atleast the high temp)
Old Jan 2, 2004 | 01:53 PM
96 WS6's Avatar
Take the header off and thoroughly clean the mating surfaces on the header and the cylinder head. If you have a leak problem RTV most likely won't help it and if it does it will easily blow out after a short time. The problem with some copper gaskets is that the raised crush collar sometimes doesn't line up with the ports on the header. The places where it doesn't line up are where it leaks most likely. You can try felpro 1406's with ultra copper smeared on them but make sure to clean the mating surfaces first. I recently had luck fixing my incurable exhaust leak by using Percy's dead-soft aluminum gasket with ARP 1" bolts. I went through 2 felpro 1406 with RTV on both passenger and driver's side before I switch to alum.
Old Jan 2, 2004 | 03:05 PM
93transam1234's Avatar
2nd
i say get some earls gaskets it fixed my leaks...
Old Jan 2, 2004 | 03:19 PM
faded93bird's Avatar
I run GM tir layer metal gaskets . they'er like 12 bucks for the set and have run them on two cars no leaks even with crappy flanges.
They are the OE replacement for 94 LT1 cars
BLK1997Z28
May 2, 2015 01:26 PM
Fatdog2
Apr 27, 2015 10:32 PM
BigWil
Mar 29, 2015 12:24 PM
alex5366
Feb 17, 2015 10:43 PM
Frank99'z-28
Jun 11, 2002 03:26 PM
