Hoods, weight of stock and aftermarket
Old Aug 7, 2003 | 09:25 AM
CANTONRACER's Avatar
I am looking at cowl hoods, I really like the look.
I have a $300 gift certificate from Summitracing, but the only cowl hood they have is the Harwood, which is a none functional hood and is really not the cowl look I am going for at all.
SO the problem is I haved called a couple people and tried to get information.
One person told me the stock hood is 60 lbs, and the hood they sell, the s-400 is 45 lbs.
Anothe person told me the stock hood is 25 lbs, and the the hood they sell, the VFN 4" bolt-on is 23 lbs.
I also called about Glasstek...could get very little information about the hood.
Looking for a bolt-on hood that weighs less than my stock 96 Z28 hood.
Any help would be appreciated.
Old Aug 7, 2003 | 09:38 AM
CeeBee94Z's Avatar
All fiberglass hoods will weigh less than your hood....I am not sure of the exact weight, but I know that the difference between a stock hood and my cowl hood that I had was probably 15-20 pounds or so...very noticeable difference
As far as functionality, no cowl hood for our cars is functional...you can probably make something to make it quasi-functional, but there are no kits at this time...
Old Aug 7, 2003 | 10:53 AM
Brent94Z's Avatar
Super Moderator
The stock hood weighs around 44 lbs with insulation...
http://www.bfranker.badz28.com/fbody/weights.htm
The VFN hood weighs what in at 22-23 lbs.
Old Aug 7, 2003 | 01:20 PM
Izod's Avatar
there is a noticable difference in the hoods. i had to lift both of them up and off/on to my car and the fiberglass hood felt like a feather compared to the stocker.
Old Aug 7, 2003 | 01:23 PM
KwikistZ's Avatar
where'd you find the VFN 4"? I could only find the 2"
Old Aug 7, 2003 | 01:27 PM
http://www.vfnfiberglass.com/932001camaro.htm
Old Aug 7, 2003 | 01:29 PM
KwikistZ's Avatar
Thanks man...that website never worked for me before
Old Aug 7, 2003 | 01:36 PM
My stock Formula hood, with insulation panel weighed 37#. Excludes hinges, struts and latch.
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
chuyz28
Nov 25, 2014 11:14 PM
