Mobil One made my car leak oil...
Old Aug 4, 2003 | 10:45 PM
joshp14's Avatar
I have about 58,000 on my TA and I decided I wanted to change to synthetic. I can get it for about $2.00/quart so I figured I'd go ahead and do it. About 2 weeks after the change, my car starts to leak oil real bad. I tried to find where it was leaking, but there was so much oil covering the block and transmission, I couldn't tell where it was coming from. I lost 1/2 quart in those 2 weeks.
I took it in to GM, they discovered it was the intake manifold gasket. They told me that the molecules in Mobil One are so much smaller than that of non-synthetic, that it got through my gasket. He said that the Mobil One isn't worth the money in my LT1 and said it's only worth to use it in High-Output engines such as vette engines and such.
I thought he was full of sh*t....but I dunno. The work was covered under my extended warranty, but should I continue to use the Mobil One? What do you guys think?
Old Aug 4, 2003 | 11:36 PM
94formulabz's Avatar
Re: Mobil One made my car leak oil...
Bwhahaha.Idiot. Please somebody tell me what a 'vette engine' is.
Anyways.....
That is a common occurance when switching to synthetic. It doesn't make you car leak, it just seeps more from existing leaks. I found that out back when i had my first jeep and wanted to put syn in it. Some jeepin buddies luckily saved me from turning my motor into one giant oil leak. It was discussed about a week ago if you try a search. If you have an extended warrenty tell them to fix the leak! not recommend a different oil.
Old Aug 4, 2003 | 11:39 PM
jasons93z's Avatar
did you tell him that it IS a vette engine.
Old Aug 4, 2003 | 11:46 PM
joshp14's Avatar
They fixed the leak...and no I didn't tell him it was a vette engine. He was referring to the newer vette's.
Old Aug 4, 2003 | 11:58 PM
so the rated extra 15 flywheel HP stock makes an LS1 "high output"?
I believe LT1 vettes came from the factory with mobil1.
Glad they fixed the leak for you.
btw i have confidence in the guys over at mobil and i use mobil 1
-brent
Old Aug 5, 2003 | 12:04 AM
joshp14's Avatar
So should I go back to Mobil One? Should I take the chance?
Old Aug 5, 2003 | 12:48 AM
RedPhenx's Avatar
if the leak is fixed.. synthetic wont cause any leaks, you are good to go.
Old Aug 5, 2003 | 01:12 AM
Zerosheaven's Avatar
i think its actualy a good idea to go with mobil one, you can discover weak areas in your engine you never would have know where there and can fix them before they become a real problem.
where the hell are you gettin mobil 1 for 2 bucks though???
send me some!! ill send you the cash!!
Old Aug 5, 2003 | 01:27 AM
joshp14's Avatar
I work at a place that sells it (i'm not at liberty to say ) and with all my discounts and coupons, it comes to $10.59 for 5 quarts.
Old Aug 5, 2003 | 01:34 AM
RedPhenx's Avatar
damn that's cheap, didnt see that price first time around...
butyeah run it, better for engine, cooler etc...
Old Aug 5, 2003 | 12:13 PM
Canadian z28's Avatar
When i first put Moblie one in the car. it did the same thing to me
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
Queens94z28
Dec 20, 2014 09:11 PM
Joes96z
Dec 13, 2014 07:48 PM
blac94Z
Nov 28, 2014 01:53 PM
USAirman93
Nov 24, 2014 03:37 PM
