Mobil One made my car leak oil...
I have about 58,000 on my TA and I decided I wanted to change to synthetic. I can get it for about $2.00/quart so I figured I'd go ahead and do it. About 2 weeks after the change, my car starts to leak oil real bad. I tried to find where it was leaking, but there was so much oil covering the block and transmission, I couldn't tell where it was coming from. I lost 1/2 quart in those 2 weeks.
I took it in to GM, they discovered it was the intake manifold gasket. They told me that the molecules in Mobil One are so much smaller than that of non-synthetic, that it got through my gasket. He said that the Mobil One isn't worth the money in my LT1 and said it's only worth to use it in High-Output engines such as vette engines and such.
I thought he was full of sh*t....but I dunno. The work was covered under my extended warranty, but should I continue to use the Mobil One? What do you guys think?
Re: Mobil One made my car leak oil...
Anyways.....
That is a common occurance when switching to synthetic. It doesn't make you car leak, it just seeps more from existing leaks. I found that out back when i had my first jeep and wanted to put syn in it. Some jeepin buddies luckily saved me from turning my motor into one giant oil leak. It was discussed about a week ago if you try a search. If you have an extended warrenty tell them to fix the leak! not recommend a different oil.
so the rated extra 15 flywheel HP stock makes an LS1 "high output"?
I believe LT1 vettes came from the factory with mobil1.
Glad they fixed the leak for you.
btw i have confidence in the guys over at mobil and i use mobil 1
-brent
-brent
i think its actualy a good idea to go with mobil one, you can discover weak areas in your engine you never would have know where there and can fix them before they become a real problem.
where the hell are you gettin mobil 1 for 2 bucks though???
send me some!! ill send you the cash!!
) and with all my discounts and coupons, it comes to $10.59 for 5 quarts.
