"search" problems
"search" problems
"search" seems to be funky. I'll enter the info, hit the search button, and it immediately tells me "no matches". Go "back" to the same search screen, and using the same info that is already entered, hit the button again, and it turns up a complete set of matches.
I've seen several posts where people will say "I tried the SEARCH but it isn't working". Might be a problem.
Fred
Fred
Re: "search" problems
Fred
Fred
Give me step by step details on how your get a page cannot be displayed error message. Be very detailed so I can try and recreate it.
I've personally never experienced a slowness problem at night.
I've had the page not found problem a lot lately.
It seems I can search several times, but if I go off to another site, then return later and try to search again, either using the quick, or advanced searches, it goes to the generic page not found page. If I reload it, then it goes to the advanced search, but does the same thing if I try to search again.
Once again....
Give me step by step details on how your getting a page cannot be displayed error message. Be very detailed so I can try and recreate it.
I want SPECIFIC search keywords, what search are you using (main page, forum, advanced?????)
Yesterday when I posted this I used first the quick search on the main forum page for:
intake rtv cure time
then just
intake
Both came up with page cannot be displayed. Tried it in the advanced search, same results. Time of day was yesterday around 2:30 EST.
I just tried again:
Page cannot be displayed, this was via quick search on the main page. Tried advanced search again, page cannot be displayed. This is when searching "all open forums"...
Searching in just LT1 tech, same results, page cannot be displayed.
Searching now for just "intake" in all open forums, takes forever to load results. Same search in just LT1 tech, gives results quickly. Searching from advanced search off main page.
As far as site slowness goes, I hate to sound like a dumb user, but it's at random times at night around midnight or so... I'll post next time it's acting up I guess. It's the only site that's slow to load for me at that point
then just
intake
I just tried again:
Try again searching for intake time using the basic search pulldown in the top nav bar.
Then, try searching for ported heads using the same manner. What happens with both searches? Same result or a different one?
Ok...
intake time
Search try #1, basic search pulldown - Page Cannot be Displayed
Search try #2, basic search pulldown - Page Cannot be Displayed
ported heads
Basic search, worked fine, little slow, but worked.
intake time
ported heads
Originally Posted by Javier97Z28
Ok...
intake time
intake time
ported heads
Try this -
Use your same search terms, but this time use the search under the particular section of the Message board that your looking for help in (LT1 or LS1, etc..).
Now, make sure you are using the Search this Forum search - NOT the very top Search in the Nav panel.
Same results just now Chris using what you suggested, page cannot be displayed.
Search term: "intake rtv cure time" under the "Search this forum" part of LT1 tech.
