Whats best way to fit C5 wheels on Camaro
Old 03-25-2019, 07:03 PM
z28wes's Avatar
I have been going over tons of forums and i am not sure what the best way to mount the rims. I have a 2001 Z28 Vert. I just picked up a set of C5 wheels, front are 245/45/17 rims are 17 x 8.5 offset 56mm. Rear are 275/40/18 rims are 18 x 9.5 offset 61mm. I tried to mount the rear wheel and the bumper stop was in way and also a piece of the front inside wheel well. I don't want to cut bumperstop or use a BFH either on the car. So im wondering if spacers are fine to use so i dont have to mod of wheel well. From what im reading people seem to have different clearances in their wheel wells. Whats the best way to measure size of spacers needed. Any help or personal experiences would be appreciated.
z28wes is offline
Old 03-26-2019, 10:22 AM
Re: Whats best way to fit C5 wheels on Camaro
My calculation indicates a 61mm offset, with a 9.5" width gives a backspace of 7.65" (this is approximate, because it requires an assumption of the width of the flanges that hold the tire on the rim). That should not be hitting the bump stop (are they stock or the aftermarket Jeep bump stops?), or the inner fenders. I have 11" wide, 50mm offset in the back, and they have a 7.93" backspace, and they do hit the bump stops and the inner fenders. With regard to the factory bump stops, the only thing that needed to be cut off was the projecting metal lip of the stop, not the actual composite stop material.
My C5 chart (verified with online sources) indicates the 97-99 wheels were 18x9.5 61mm in the back. But those aren't 97-99 wheels in the pic. They are 2000 and up, and my chart shows them as 18x9.5" 65mm offset. That bumps the backspace up to 7.81", which should still give you a bit of clearance to the bump stop and inner fenders.
Measure the backspace. Put a straight edge across the flanges of the wheel (not touching the tire) and measure from the bottom of the straight edge to the face of the hub mounting surface.
Did you try fitting the rear wheels to both sides of the car? If not, the rear of the chassis may not be centered exactly over the rear axle assembly, and the wheels would only hit on one side. Is your car lowered? Do you have an adjustable panhard bar?
Injuneer is offline
Old 03-26-2019, 11:08 AM
z28wes's Avatar
After doing some more reading i just realized i jacked car up by the body not on axel, so thats seems to be why im touching the bumper stop. The car is not lowered and i did not check the other side to check alignment. i have a panhard bar but not sure if its adjustable. So these wheels front and back should fit with no issues. I did alot of reading before i bought them but since i lifted car wrong that should be my issue, will try tonight. Thank you
z28wes is offline
Old 03-26-2019, 03:03 PM
You have several things to consider:
  • You need to check the fitment with the car jacked by the axle. Just remember - if you have to jack the car by the chassis for a roadside tire repair, the edge of the bump stop may still move upwards and can catch the edge of the rim or the edge of the tire, causing damage.
  • You need to check the fitment on both sides of the car. If the chassis is off center, one side may be fine and the other side may hit something. Because of the design of the panhard bar, as the chassis moves up and down, it moves sideways due to the fact the panhard bar is moving in an arc. The spacing side-to-side can change by as much as 1/4".
  • Your situation is made worse with regard to rubbing on the inner fender, because the rear tires you have are 1" larger in diameter than the stock tires, and stick up 1/2" further into the wheel well. Your speedometer will read 3.7% lower than actual speed. At a true 60 MPH, your speedo will read 57.7 MPH.
  • The larger than stock offset pushes the wheel deeper into the wheel well. If you like that look, no problem, But if you prefer the outer edge of the wheel/tire closer towards the outside of the fender, a specer (actually an "adapter") is the only way to achieve that. Stock wheel "frontspace" is 2.33". The 65 mm offset wheel will have a 2.69" frontspace. You can move the wheels out a full inch with adapters, and the edge of the tire will still be under the rear fender. I run a 4.0" frontspace, and the tire is still under the very edge of the fender. See photo above. Your tires will be about 1.25" deeper in the wheel wells than those in the picture.:
Injuneer is offline
Old 03-27-2019, 07:37 AM
z28wes's Avatar
i was able to get the wheels on once i jacked up from the rear end not the body. the rear end look centered both sides are equal. i am very close to the inner wheel well and bumperstop i wouldn't want to drive it the way it is. I will be ordering wheel spacers/adapters
z28wes is offline
Old 03-30-2019, 01:59 PM
z28wes's Avatar
For your wheel spacers did you cut your wheel studs or replace them, is it same to cut them and how much can you cut before it becomes unsafe
z28wes is offline
Old 03-31-2019, 09:28 PM
I didn’t have to use spacers. What thickness spacer/adapter are you using?
Injuneer is offline
Old 02-11-2020, 11:49 AM
lenarish's Avatar
for a wheel R18 / 275/45 with a offset of 65 mm, a 10 mm spacer is necessary.
lenarish is offline
brewsterj944
Wheels and Tires
05-11-2019 08:30 PM
95Power
Wheels and Tires
13
08-01-2013 05:50 PM
crazyswede1027
Wheels and Tires
08-24-2012 08:18 PM
camarolt4ss
Wheels and Tires
12-29-2006 09:37 AM
x7x7
Wheels and Tires
10
09-11-2006 02:37 PM
Quick Reply: Whats best way to fit C5 wheels on Camaro
