will a 95 lt1 work on a 97 lt1 camaro with my harness and pcm
Old 03-26-2014, 06:00 PM
sini5terSS's Avatar
Hello my name is jesus and im new to this forum. I have a 1997 ss and thy are selling my a 95 lt1, will that motor run with my computer and harness
Sent from my SGH-T769 using Tapatalk 2
sini5terSS is offline
Old 03-27-2014, 09:16 AM
Re: will a 95 lt1 work on a 97 lt1 camaro with my harness and pcm
The 95 LT1 does not have the crankshaft position sensor, which the 97 does have. As a result, you will get a code for the missing sensor, but the engine will still run. The CKP sensor was added in 1996 to meet the OBD-2 requirement for misfire detection. There is also an EVAP system vacuum detection switch on the passenger side valve cover of the 97 that will have to be transferred to the 95 engine, to avoid codes for the EVAP system.
If you decide to swap the CKP sensor from the 97 to the 95 engine you will need to transfer the timing cover, the sensor in the timing cover, the reluctor wheel on the nose of the crankshaft, the woodruff key for the CKP reluctor and crank sprocket, and use the crank hub from the 97 since it has to be shorter to allow the reluctor wheel to fit.
Also check the AIR pump components, because one or both of the engines may have had the "AIR pump recall" modifications done to it.
Injuneer is offline
Old 05-04-2014, 01:34 PM
sini5terSS's Avatar
Thanks sorry I was out for a while but my wife had our second child and I have been taking cake of him.
Sent from my SM-G900T using Tapatalk
Old 01-19-2019, 06:31 AM
Lloyd Singleton's Avatar
Mines started and ran for only like 10 seconds and killed
Lloyd Singleton is offline
Old 01-20-2019, 09:33 AM
Confusing.
Is this a request for help, related to your other two posts?
Injuneer is offline
01-25-2014 08:30 AM
Henson071
03-03-2011 02:40 PM
spike30th
06-02-2009 07:32 PM
Carlos26
04-25-2007 09:40 AM
Mauiguyy911
02-13-2007 04:59 PM
Quick Reply: will a 95 lt1 work on a 97 lt1 camaro with my harness and pcm
