Zaino question (time?)
Subscribe
Mar 31, 2002 | 02:49 PM
i washed the car with dawn, clayed it, washed with Z7, applied Z1, waited 12 hours, applied Z5, waited 12 hours, removed it. My question is: Do i need to wait 24 hours before i can put on the next coat of Z5?
-Jeff
1998 Dark Blue Metallic Z28, chrome rims, chrome lug caps from SLP, RK Sport ground effects package w/spoiler, BFG VR4 tires, Quad tip flows, LS1 Motorsports Lid, K&N air filter, MSD Ignition wires, BOSCH Platinum +4 spark plugs, SLP Bellows kit, custom painted interior, and a BIG RED BOWTIE in the back window =)
Reply
Mar 31, 2002 | 04:16 PM
Hey Jeff,
After removal of Zaino Z-2 or Z-5, you should wait 24 hours if the outside temperature is under 70 degrees and 6 hours if over 70 degrees, before applying the next coat of Z-5 or Z-2.
From your post it sounds like you waited 12 hours after applying Z1 to apply Z5. Z2/Z5 are supposed to be applied directly over Z1 immediately after you finish the car with Z1. Z1 dries almost instantly, it does not need to set up or cure like Z2/Z5. By the time you do the whole car with Z1, it will be completely dry and ready for your Z5 or Z2.
Good Luck!
*Mike's 1992 Camaro RS 25th Anniv.*
Dark Red Metallic (ext.) / Flame Red (int.)
Flowmaster Crossflow, K&N, 20% 3M Panther Black Tint
JL Audio 3 10", PPI PC2100, Kenwood eXcelon KRC-953H/U, Kenwood / Pioneer speakers
Shine by ZAINO! - Special Thanks to Sal Z!
Reply
Mar 31, 2002 | 07:56 PM
so how long do i leave Z2/Z5 on for? just until it dries?
-jeff
Reply
Mar 31, 2002 | 08:04 PM
Z-1 does not dry unless it makes contact with Z-2 or Z-5, Z-1 is ready for Z-2 or Z-5 as soon as the Z-1 touches the paint. Z-1 is the activator for Z-2 or Z-5.
After Z-1 and Z-2/5 dry, remove with a cotton towel and enhance the gloss with a coat of Z-6 immediately.
A coat of Zaino will cure in 6 to 7 hours if the air temps are above 70 degrees, wait 24 hours for the next coat to build layers if colder than 70.
96 Black Impala SS
Authorized Zaino Showcar Polish Distributor
www.zainobros.com
Remember #3
Reply
Mar 31, 2002 | 08:07 PM
so all i have to do is put on a coat of Z5, let it sit for 6 hours, take it off, then let the nice shiny paint sit there for 24 hours?
-Jeff
Reply
Mar 31, 2002 | 08:13 PM
Let it dry, not sit. Once dry remove it. An experienced Zaino user can apply it thin enough where it will be dry in 30 minutes, unless really humid or cold. If it is taking 6 hours to dry, you are using WAY too much. Nobody said you have to leave your car sit for 24 more hours either. If the car isn't dirty, just use a California Duster and then some Z-6 to get the surface clean as possible and apply another coat. I drive mine all the time between coats.
It is ALOT easier than you think, if it isn't, you're doing something wrong.
Kevin Villier, 2002 SS #186 - 6M with Hurst and "short-stick", TT, navy blue, chrome SS wheels, Bilstein suspension, SS grill, STB, SLP loudmouth, Direct-Flo lid with Holley filter and Mallory polished MAF ends.
Louisville, KY
[This message has been edited by Kevin V 2002 SS (edited March 31, 2002).]
Reply
Mar 31, 2002 | 08:19 PM
ok i got it now! =), anyway, it dries in about 45 min. So i should take it off as soon as it is dry, then let it cure for 6 hours (80 degrees right now)
-Jeff
Reply
Apr 1, 2002 | 06:41 AM
YUP!!!
Louisville, KY
Reply
Subscribe
