Zaino question? for MikeLS
Mike Ive been thinking of trying Zaino for a while on my 95 Formula. The clearcoat on my car seems to scratch very easy.In your opinion does the polimer coating that is laid down when Zaino is applied harder than the factory clearcoat.I also have alot of very fine scratches that Im hoping to cover up.My bird has only 35k on it and is garaged always.The lady I bought it from washed it at the local carwash and it has caused these scratches.Ive used some Turtlewax clearcoat plish and it works ok but if you look you can see them still.So what do you think........Thanks Mark
No matter what kind of durable polish or wax, whether it is Zaino or not, will not be as hard as your clear coat paint.
Follow these tips for swirls and scratches:
98% of all cars have swirl marks and fine scratches including brand new cars.
Why? Because of dealer prepping and using an abrasive polish combined with the
wrong towels and incorrect washing of towels. Abrasives and Polyester in towels are
the most common causes of swirl marks and fine scratches, especially on brand new
paint finishes. The dealer is the first person to start the swirl process on a paint
finish.
Here's a way to check if your paint has swirls or scratches. Look at your paint finish
under fluorescent lighting. This will let you see every mark on the paint surface.
Then you be the judge.
Store bought Swirl removers are just a temporary illusion and a Band-Aid
approach to the problem.....
I am totally against using abrasives on paint finishes. Abrasives, no matter how fine,
create new scratches, they should be avoided and only used when absolutely
necessary. And then only by a trained professional. The clear-coat on today's paint
finishes is very thin and abrasive products will thin it even further and hurt it, in
the long run creating many more swirl marks and fine scratches.
All swirl removers contain abrasives and are loaded with silicone oils and other oils.
Zaino Show Car Polish contains no Abrasives or Silicone oils. Although abrasives
remove scratches they create new scratches and swirls and they thin out the
clear-coat. Silicone oil camouflages swirls and scratches, temporarily, as soon as the
oil washes away or evaporates the swirls are visible again. Kinda a Catch-22. Z-5
fills swirls and scratches and does not create any new scratches. Because Z-5
durability is so high and will not wash away. The scratches will stay filled. That's
the hot ticket to a flawless paint finish.
The Z-5 is applied, as per directions, and will fill swirls and scratches in stages. One
to three coats of Z-5 depending on the amount and degree of scratches. Z-2 should
always be the last coat of polish on the car. Z-2 has higher optics than Z-5. You can
go from Z-2 to Z-5 and back to Z-2 anytime you like. Always use Z-6 "Gloss
Enhancer spray between each and ever coat of Z-5 or Z-2.
With deeper swirls and fine scratches sometimes the use of an mild abrasive product
like 3M Foam Polishing Pad Glaze Swirl Mark Remover #39009 is necessary.. I try
to avoid the use of abrasives and would try my best with Z5, to see if it will correct
the problem. However if you don't see a visible difference after 1 or 2 coats of Z-5.
Waiting 6 to 24 hours between coats of Z-5... Then you need to use the 3M Foam
Polishing Pad Glaze Swirl Mark Remover #39009... see following tips...
3M Foam Polishing Pad Glaze use By hand:
Simply apply a small amount (about the size of a quarter) to a cotton diaper or piece
of cotton towel and rub back and forth into about a 1'X 1' section using light to
medium pressure until it starts to dry out. Then take a second towel and lightly rub
back and forth until the polish residue disappears and the gloss comes up. If there
are still some swirls visible you can repeat this step until they are minimal. I prefer
using a less aggressive product a couple times instead of using a more aggressive
product once. After you have done the entire car you can Dawn wash and reapply
your favorite wax/polish or Zaino Z-1 and Z-5/Z-2.
3M Foam Polishing Pad Glaze use By orbital:
Use a 100% cotton bonnet or a foam bonnet and apply the polish in a thin lined
growing circle starting from the center and spacing the growing line about an inch
from the last round all the way to the edge. Place the bonnet flat on a panel and
activate the polisher and begin working the entire panel using light to medium
pressure. When you have worked the panel thoroughly then take a clean towel and
wipe the residue off in a back and forth motion using light pressure. Then simply
move to the next section. When the entire car is done do a Dawn wash and Zaino.
DO NOT ever use cotton T-shirts on your car. They contain polyester and will cause
swirl marks and scratch your paint finish. Use my #314 applicator pad for applying
my polish. Read my Tips & Tricks sheet. www.zainobros.com
Towels must be 100% Made in USA. Name Brand(Cannon or Fieldcrest Towels).
These towels are always 100% Cotton. Most other Brand name towels I've analyzed
are not 100% Cotton but a blend of cotton and polyester. The cotton material is
from overseas and is not federally regulated. Even though they say 100% Cotton
they are not.
You must use only white. Not colored towels.....Colored towels are not to be used
because the dye leaves a chemical residue on the paint finish. Always wash your
towels first before using. Use Liquid detergent and rinse twice. Do not use Powdered
detergent, Bleach or any type of Fabric softener. Make sure to run rinse cycle twice
to remove all detergent.
You should cut the selvages(borders) off the perimeter of the towels. This selvage
contains nylon and polyester stitching that could possibly scratch your paint finish.
The towels will fray a little once this is done. But it's better to play it safe.
Drying the towels on high heat will make them hold a static charge. I use the regular
heat setting and remove them a little damp and let them air dry. You can fluff the
towel real good when it's dry to make it softer.
As the towels get older they will lose there nap and absorbency and will have to be
replaced.
I don't like sponges natural or synthetic, they all can scratch...
Another great tip is to use a Toro 210mph Electric leaf blower. Dries your car in
about 5 minutes.... without even touching the paint surface....
96 Black Impala SS
Authorized Zaino Showcar Polish Distributor
www.zainobros.com
Remember #3
finish.
they are not.
replaced.
96 Black Impala SS
www.zainobros.com
Remember #3
Thanks Kevin, My car is dark blue and Im sure that I can get away with out the abrasive.I was a detail manager and I buffed hundreds of cars and I never did one that I didnt leave some kind of small swirls.I agree that buffing is bad for the paint and I think Zaino is just the thing.Ill try it I just have to save the bucks for a starter kit.....Thanks again.....Mark
Yeah, adding a little to what Kevin said, the best approach to lessen or eliminate swirls and scratches is to start out from the least aggressive product and moving to more aggressive if the results aren't improving. Zaino is head and shoulders,(in terms of protection, durability, and possibly shine), above TurtleWax and nearly ANY carnauba based product. So, your best bet would be to start out with Z5 which helps fill in fine swirls, and is completely nonabrasive. If you're still seeing moderate/heavy swirls after a few coats of Z5 you'll probably need a mild polish to take out the deep ones. I'd recommend Meguiar's Medallion Cleaner as it contains a minimal amount of actual polishing oils to improve gloss. It mainly deep cleans your paint. If you're satisfied after a few coats of Z5 though, there will be no need to use a more aggressive polish. For a basic starter kit, try Z1 or ZFX(not both) Z5, Z2, and maybe Z6 & Z7 if you want to spend more. I also highly recommend a clay bar if you've never done that before. Zaino Z18 clay is one of the best out there and comes in two yellow bars. Works wonderfully!
Zaino may seem like a lot of products or complicated steps, but it's really not. You simply apply Z1, then either Z2 or Z5 for the initial application (assuming you have clayed or polished if needed, and used DAWN to strip other waxes off). Then, just reapply Z2 or Z5 whenever you like. Sometimes I actually feel as if I'm not doing enough to my paint because Zaino is soooo easy compared with other systems out there. Give it a shot and I think you'll be thoroughly impressed especially on a dark blue car. Your paint will really pop with shine and clarity with Zaino.
BTW, never use automatic car washes. Always wash by hand to avoid potentially serious paint damage, and likey heavy swirling and scratching. And, always use 100% cotton products for washing, applying, and buffing your car.
Mike
*Mike's 1992 Camaro RS 25th Anniv.*
Dark Red Metallic (ext.) / Flame Red (int.)
Flowmaster Crossflow, K&N
JL Audio 3 10", PPI PC2100, Kenwood eXcelon KRC-953H/U, Kenwood / Pioneer speakers
20% 3M Panther Black Tint
ZAINO! - Perfect Shine in Less Time!
My Guitars, Metallica Style!
[This message has been edited by MikeLS (edited January 07, 2002).]
Mike
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
