Z18 Clay Bar Question
Alright, hopefully this will be my last Zaino related question for some time: Should only a torn off part of the Z18 Clay Bar be used to clay the car or should the entire bar be used?
Oh, and one last thing: Would it be a good idea to go over the car with 3M Swirl Remover before Zainoing? I wouldn't call my spider-webbing bad (it can only be seen at certain angles in the sun) but if it would make a noticeable difference I'd like to do it.
Thanks,
Josh
[This message has been edited by JoshWhite (edited December 27, 2001).]
Thanks,
Josh
<font face="Verdana, Arial" size="2">Originally posted by JoshWhite:
Thanks,
Josh
[This message has been edited by JoshWhite (edited December 27, 2001).]</font>
Thanks,
Josh
Do not use the 3M unless you have a BAD swirl problem.
96 Black Impala SS
Authorized Zaino Showcar Polish Distributor
www.zainobros.com
Remember #3
Interesting!
I used one whole bar when I did my car...
I must have wasted Clay... but it felt liek a good size to use...
Darth Xed
1999 Camaro Z28
LS-1 6 Speed
Mods: Borla Cat-Back; Bridgestone Potenza RE730's; MTI Air Lid; Holley Power Shot; Flux-Capacitor
I must have wasted Clay... but it felt liek a good size to use... ------------------
Darth Xed
1999 Camaro Z28
LS-1 6 Speed
You didnt waste any clay. I've used the mothers clay bar and I ripped it in half in case I dropped part. That way, I still have half of a clay bar to use instead of no clay bar.
Chris™
<A HREF="http://www2.gvsu.edu/~stigersc/lakepics.htm" TARGET=_blank>'97 Cutlass Supreme SL coupe - Bright Red
</A>
Chris™
</A>
<font face="Verdana, Arial" size="2">Originally posted by SinisterSyclone:
</font>
</font>
96 Black Impala SS
www.zainobros.com
Remember #3
I use the Zaino clay bar as supplied, but I only clay with 1 side. When that side becomes dirty I stretch the bar to about double it's length and fold the dirty side in on itself. That leaves a bar with 2 clean sides. Now I use one of the clean sides and when it get's dirty I stretch the bar .... I've done this about 18 times on 1 clay bar before I moved on to the next one.
Ira
Ira
A clay bar can be used more than once, unless the car was REALLY full of gunk. I've used the same bars over and over. Keep kneading it alot to maintain a clean surface.
Kevin Villier, 2002 SS #186 - 6M with Hurst and "short-stick", TT, navy blue, chrome SS wheels, Bilstein suspension, SS grill, STB, SLP loudmouth, Direct-Flo lid with Holley filter and Mallory polished MAF ends.
Louisville, KY
Louisville, KY
