Z1 question?
I've claybared two of my Camaro's one Silver the other Black, put on the Z1 on the silver. Really had a hard time seeing it being applied, just figured that's because the car is silver. Used the Z1 on the Black and still had a difficult time seeing it. I'm not skimping on this either, my applicator is wet w/ the Z1. Is this Normal?
I 'm just second geussing myself and wanna make sure I'm doing this correctly.
67' RS/SS Convertible 100% stock
67' RS/SS 427 too many mods!!!
00' SS M6 Hurst Shifter All SLP High Performance Options, Direct-Flo lid w/ KN filter
"Speed is just a question of money...how fast do ya wanna go!"
It is difficult to see, especially on certain colors. Look at the bottle and see how much of it you used. It will only take 1 oz. to do the entire car. It does go on in very thin layers. If the pad is damp with the Z-1 and you are covering all the areas you are probably OK. For a first time with a car I usually go over it with Z-1 on the third polishing application again just to make sure, in case i missed any areas with the first application.
Kevin Villier, 2002 SS #186 - 6M with Hurst and "short-stick", TT, navy blue, chrome SS wheels, Bilstein suspension, SS grill, STB
soon to add: SLP loudmouth, lid and MAF ends
Louisville, KY
Louisville, KY
Perfect! that is how Z-1 is supposed to work, all Z-1 has to do is make contact with the paint in a micro micro thin layer, if you see any you used too much. Also, if you apply Z-1 with a damp pad, sometimes the results will not be what you want as the Z-1 sheds water, I like to put Z-1 on with a dry pad.
96 Black Impala SS
Authorized Zaino Showcar Polish Distributor
www.zainobros.com
Remember #3
96 Black Impala SS
www.zainobros.com
Remember #3
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
