So here's what I bought...
Old May 11, 2004 | 01:46 PM
IrocManiac's Avatar
6 inch powered buffer
NXT wax
Maguires Polish
Maguires Paint Cleaner
Maguires Clay bar
wash mit
polishing cloths
wheel/tire cleaner
fuel injector cleaner (unrelated to detailing)
I think I got everything, so I start with the wash, then clay bar it, then use the polish, then the wax according to maguires...does that sound right to everyone? How many coats should I give it?
Old May 11, 2004 | 02:02 PM
MustangEater82's Avatar
Minus the buffer, and fuel injector cleaner how much did that cost?
Old May 11, 2004 | 02:24 PM
IrocManiac's Avatar
About 55 in all excluding the other stuff, the injector cleaner was about 10 bucks, the buffer about 30 with extra pads..so more like 51 cause my total was 91.91
Old May 11, 2004 | 10:25 PM
6']['9's Avatar
if you bought the maroon bottles id take them back. you can go
wash
clay
swirl mark remover or meguiars 9
polish or show car glaze meguiars 7
wax meguiars 26
or top with NXT
Old May 11, 2004 | 11:41 PM
lbls1's Avatar
Good choice. Wash, clay if needed, paint buff cleaner (important), polish (good, but you can skip it if you're pressed for time), finish with 2 coats of pure wax (most important, make sure its pure wax, not a cleaner wax. If its a cleaner-wax, take it back and get a pure wax).
Get going! Do not re-clean after the wax (unless somehow you get more contaminants. If that happens you should clay again). You shouldn't get more particles though if you are on top of your detailing routine. Just compound your efforts with wax layers until you are satisfied with the result.
Finally, wax season is here!
Old May 12, 2004 | 12:07 AM
IrocManiac's Avatar
I bought NXT wax, two layers should be good you think? I called maguires they said 1 was fine, but I'm game for 2 or three if thats better, I assume you apply a layer wipe it down and then apply the next layer right?
Old May 12, 2004 | 10:43 PM
lbls1's Avatar
Yup 2 layers is good as a start. Buff wipe your first layer, then add the second. Follow their directions as to whether you will need to buff it again a few hours later.
Build your wax finish slowly over a season, and you will go like this
Good luck.
Old May 14, 2004 | 06:30 PM
PoloGreen 3.4's Avatar
Wait, so you can layer NXT?
qnitro
10
May 17, 2009 01:54 AM
Bluovlh8er
Exhaust System
Apr 3, 2008 09:25 AM
