remove wax/sap?
Old Mar 14, 2013 | 04:13 PM
ablkbrd's Avatar
remove wax/sap?
need help removing sap or wax... or something. this stuff is like glue, it just will not come off. i can scratch it off with my finger nail but its all over the car. help please!
Old Mar 14, 2013 | 05:16 PM
jloshotz's Avatar
remove wax/sap?
There is a solvent actually called bug and tar remover, I know auto zone carries it. Google "bug and tar remover" and you'll find it
Old Mar 14, 2013 | 06:33 PM
moparman's Avatar
Re: remove wax/sap?
A clay bar might get it. Dawn dish washing liquid and a mesh type sponge might help.
Old Mar 15, 2013 | 12:05 PM
ablkbrd's Avatar
Re: remove wax/sap?
thanks guys, bug and tar remover a no go... clay bar is next. then rubbing compound... this sucks. dont want to kill the paint.
Old Mar 17, 2013 | 03:43 PM
Randy Bilyea's Avatar
Re: remove wax/sap?
Tree sap: Ice it down and peel it off with your nail. Got to get it really cold though. Not a problem HERE right now...
Old Mar 17, 2013 | 07:50 PM
96 Z 28's Avatar
Re: remove wax/sap?
I've heard Goof-Off or Purell Hand Sanitizer.
Old Mar 18, 2013 | 04:01 PM
parkers Z28's Avatar
Re: remove wax/sap?
The clay bar should do it .... be careful with the rubbing compound !!!!!!!!!! look at what size
the grit is in the rubbing compound ... try it out in a small spot to make sure it does not eat the paint off I would try several things before I would use a rubbing compound !!!
There is a big difference between rubbing compound and a polishing compound
Old Mar 19, 2013 | 11:05 AM
30th97z's Avatar
Re: remove wax/sap?
Meguiar's Clay Bar!
Old Mar 21, 2013 | 03:42 PM
ablkbrd's Avatar
Re: remove wax/sap?
weather has been crappy... it does peel off when its super cold out.. but spring will be here by the time i use my thumb naul to get it all. havent used the clay bar yet but hopeful
Old Apr 2, 2013 | 12:06 PM
Scrub88's Avatar
Re: remove wax/sap?
Had this same problem while parking my daily truck under pine trees at work ..covered in this goo ..I used denatured alcohol it removed it pretty well and I used wd40 as well it didn't seem to have any effect on the paint . Might try that in a small spot to test .
Old Jul 20, 2013 | 07:45 AM
websdown's Avatar
Re: remove wax/sap?
I have used alcohol and it worked on black with clear coat no bad effects or dulling and have used clay bar on small pin head type sap spots from Black Walnut trees if baked on. Other wise a lot of regular tree saps come off with just water/Except PINE SAP. But I would try the Alcohol before I would use rubbing compound as long as you have clear coat on top. GOOD LUCK.
greenzee28
Sep 25, 2015 04:29 PM
Jake Bialke
Sep 24, 2015 11:31 AM
wbspoon
Sep 19, 2015 08:12 AM
NewsBot
Sep 14, 2015 09:20 AM
RX Speed Works
Sep 11, 2015 03:31 PM
