painting the z28 need help
Old Mar 12, 2006 | 12:34 PM
fya95camaroz28's Avatar
im bout to paint my car i need to know many sprayable qt's of base coat will i need im going black, i need to know how many qt's of klear will need i wannt to to shine btight and i want to add a pearl to the klear hok red ice preal how maby oz will i need to buy thanks im usein hok black,klear,red ice preal let me know how much of this i need to paint a 95 camaro z28
Old Mar 12, 2006 | 03:04 PM
Re: painting the z28 need help
ttt i need to order this asap please help me you guys
Old Mar 13, 2006 | 04:28 PM
Silvershark's Avatar
Go down and talk to your local paint jobber. They will let you know how much material you will need. I would also suggest looking into purchasing some painting videos.
I highly recommend Paintucation "Paint your car", by Kevin Tetz. Here is a link.
http://www.paintucation.com/
You can purchase the same dvd's off ebay for a little less too.
Old Mar 16, 2006 | 12:50 PM
CamaroCasanova's Avatar
Most base coats mix 1:1 with the reducer/basemaker. So I would say 3/4 gallon minimum for just the outside no other jambs or anything to make sure you have plenty. The clear mixes 4:1 with the activator in most applications, and sprays thicker, I would say around 1/2 gallon, from what I recall I haven't painted anything in a while that large. You can always go and get more or have someone go and get more while you are painting if you run out.
Old Mar 16, 2006 | 10:52 PM
Ryatt-SS's Avatar
HOK base coat is a high solids formula so you will really only need about 2 quarts of black, just spray on 3 coats. As for the clear coat, I would just get a gallon becuase with black paint, I have always found it best to lay down 6 coats of clear, 3 first, then cure, then wet sand with 600g and 3 more coats and you have one deep black pit for a paint job.
Patricklt1
Apr 24, 2015 06:29 AM
Brake_L8
Jan 20, 2015 09:44 AM
rockync7
Jan 1, 2015 05:10 AM
ModdedNerd
Dec 14, 2014 10:28 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
