Paging KevingSS: Por15 Question
Old Apr 29, 2002 | 07:35 AM
NewIn95's Avatar
Post Paging KevingSS: Por15 Question
After reading a post about wheel wells looking horrible, I went and ordered some of the semi gloss por 15 that you have used. I can't stand the way the rear wheel wells look when the car starts to age!
I have applied one layer of por 15 on both sides but my question is this: Did you only apply one layer or multiple? In some spots, I went back over it to fill in some of the "pores" that I missed. Now that it has dried, the portions that I went back over are a tad darker than the rest. Will this fade/dry with more time or should I apply another layer to the rest of the surface to match the darker portions?
This is the first time I've used it so I figured I would check to make sure. This stuff comes with more warnings that anything I've ever seen
Thanks!
Rapid Motorsports
www.TheFBodyShop.com
1999 Hugger Orange Z28 w/sports appearance package
A4, 4.10's, Whisper Lid, Hooker Cat-back, Vigilante 4500, !EGR, !Air Pump, FLP Longtubes, y-pipe (offroad pipes), Lunati Cam, LS6 Intake, SLP 85mm MAF, Ed Wright Custom Tuning
Best ET. 11.949 @ 113.16 - Full weight, drag radials
Old Apr 29, 2002 | 09:39 AM
ROCKN SS's Avatar
Post
It is supposed to cover with one coat, however you can add multiple coats if you like. Since it's in the wheel wells I wouldn't think that a different shade would be too noticeable once the wheels are back on. P0r-15 is not UV protected and will fade/change color is sunlight, however that shouldn't be too much of a problem in the wheel wells.
Did your wheel wells originaly have an undercoating in them? If so did you paint over this or remove it? If you removed it what did you use?
Old Apr 29, 2002 | 09:45 AM
NewIn95's Avatar
Post
I painted right over it.
I realize you won't see most of it but I still want it to be uniform, I guess I'm ****
Old Apr 29, 2002 | 11:13 AM
KevinSS's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by NewIn95:
</font>
I re-do mine every 2 or 3 years as it is show car sometimes, I usually have great luck with one coat.
96 Black Impala SS
Authorized Zaino Showcar Polish Distributor
www.zainobros.com
Remember #3
Old Apr 29, 2002 | 11:23 AM
NewIn95's Avatar
Post
I'm in the same boat, I still show my car. I'll probably try to add another coat where it isn't as dark in the spots that I mentioned.
I love the results even with my unevenness! Make's it look that much better...
Old May 5, 2002 | 08:45 AM
chr10spoke's Avatar
Post
is one qt. good enough for all wheel wells. Thinking about getting this product. thanks
Old May 5, 2002 | 11:21 AM
KevinSS's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by chr10spoke:
is one qt. good enough for all wheel wells. Thinking about getting this product. thanks</font>
Actually, one pint if usually enough.
96 Black Impala SS
www.zainobros.com
Remember #3
DirtyDaveW
Dec 1, 2016 05:37 PM
cmsmith
Mar 16, 2015 02:34 PM
ChrisFrez
Mar 8, 2015 01:22 PM
Caps94ZODG
10
Sep 9, 2002 12:08 AM
Brent94Z
Mar 21, 2002 04:44 PM
