I Need Protection From Frt End Paint Chips..can Anyone Help??
Does Anyone Know Of Any Items Or Products That Protect Against Those Irritating Front End Paint Chips That Are Caused By Tiny Rocks And Road Debris???...any Help Appreciated!!...
Re: I Need Protection From Frt End Paint Chips..can Anyone Help??
FAQ's you should know (regarding these plastic Bras) from Invisible Mask:
Can I reuse this material once opened?
No, Paint Protection film must be applied immediately upon being removed from its backing. The film can not be removed and reused once applied.
Can it be removed?
Yes. It can be removed easily and will not damage the paint. To remove the film, you must heat the surface to approximately 150°F while working a corner of the film with your fingernail. Once you have enough of the material free from the surface to hold on to, slowly pull the film from the paint.
Can it be removed?
I got this 3M protection film over at http://www.invinca-shield.com
Had it on for 3 years and still looks great.
Victor Lamb
Aug 26, 2017 02:52 PM
carguyshu
Jan 22, 2017 11:19 AM
Apr 3, 2015 10:54 AM
