how is zaino on scratches and swirls?
Old Nov 16, 2001 | 12:31 AM
Reg Kmet's Avatar
Post how is zaino on scratches and swirls?
just curious because i have numerous swirlies, and before i plunk down 175 for zaino, i gotta make sure this stuff will help!
1995 Pontiac Firebird "Blackbird" 3.4l v6 5 speed
PERFPRMANCE MODS
- Throttle Body Coolant Bypass
- K&N FIPK
- Hypertech Power Pullies (Crank &Alt)
- Accel Coilpacks
- Accel 8.8mm plug wires
- AC Delco Rapidfire plugs
- 180 degree thermo
APPEARANCE
- Red and black Alpena racing pedals
- 2 1/2% Limo tint on the sides, tinted hatch
- 98+ style rear centerplate bird and text (red)
- Red Pontiac inlay
INTERIOR
- Panasonic CQDF 800u Headunit
- Custom modded rear speaker mounts to fit 6x9's stealth!
- 2 MTX thunder 280's
- 2 Cerwin Vega AI 12's in a custm enclosure on the rear deck
Old Nov 16, 2001 | 06:19 AM
Kevin V 2002 SS's Avatar
Post
The Z-5 polish is thicker and helps to gradually fill the swirls and small scratches. It works really well, but if your car is that bad it may take alot of coats to fill them in completely. With the swirls being that bad, you may want to look at your technique and the towels, etc. that you use.
Kevin Villier, 2002 SS #186 - 6M with Hurst and "short-stick", TT, navy blue, chrome SS wheels, Bilstein suspension, SS grill, STB, SLP loudmouth, Direct-Flo lid with Holley filter and Mallory polished MAF ends.
Louisville, KY
Old Nov 16, 2001 | 06:20 AM
Wildcat's Avatar
Post
The Z-5 will help to reduce swirl marks over time. It may take a few applications of Z-5 before they diminish, but they will go away.
If your swirl marks are very bad or you have light scratches, you may want to pick up some 3M Swirl Mark Remover (39009) and use this before you start the Zaino process.
Old Nov 16, 2001 | 12:15 PM
Reg Kmet's Avatar
Post
here in canada all i can get is 39006!
Old Nov 17, 2001 | 08:18 AM
dylan's Avatar
Post
I wish I had pictures to show you, but I have a black '94 T/A and with the help of Z5 the car looks brand new and better than most new black cars. Just make sure you use the clay bar first, this will make your polish application that much easier, the before and after difference will be incredible. I rarely use Z2, I'm hooked on Z5. The more I use it the better the car looks. I think it's reached it's maximum potential just by the comments I get alone. Good luck...
Old Nov 17, 2001 | 08:24 AM
dylan's Avatar
Post
Actually, the 39009 is available in Canada. I found some at a paint/auto parts store. It may be your location are you in the middle of nowhere? I don't even like using the 39009, I tried a small spot once and was not impressed with it's application.
Aug 17, 2015 09:50 AM
surreybrad
Jul 29, 2015 02:55 PM
Fastbird93
Jul 11, 2015 04:37 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
SSRox
Aug 29, 2001 06:52 PM
