How to make paint in engine bay look good?
Old Aug 16, 2002 | 08:43 AM
SNEAKY NEIL's Avatar
Post How to make paint in engine bay look good?
I was wondering how I can do this. I have tried a few different things and they don't seem to work all that well and the painnt still looks dull. Thanks.
95' Z28 M6 (bright red)
-Borla exhaust, Edelbrock 1 5/8" headers and Y-pipe, no cat, G2 cold air, Edelbrock 52mm throttle body, underdrive pulleys, Crane Gold roller rockers,Crane valvesprings, 3.73 gears, MSD 6AL and MSD wires, free mods.
-Hurst shifter, Bilstein shocks, Eibach springs, Metco control arms with relocation brackets, Hotchkis panhard rod, SLP subframe connectors, BMR STB, 1LE aluminum driveshaft, 1lE tranny mount, PolyEurethane end links, TA girdle.
Old Aug 16, 2002 | 08:57 AM
MikeLS's Avatar
Smile
Have you tried a cleaner/wax type product? This should remove some of the dullness and add a little shine too. Before you add anything though, you should clean the engine area with a degreaser product to remove any loose dirt buildup. Of course, cover all the proper components if you use a degreaser and water. Afterwards, a cleaner/wax should do the trick...
*My 1992 Camaro RS 25th Anniv.*
Dark Red Metallic (ext.) / Flame Red (int.)
Flowmaster Crossflow, K&N, 20% 3M Panther Black Tint
JL Audio 3 10", PPI PC2100, other Kenwood & Pioneer goodies...
Show Car Shine by ZainoBros! - Thanks Sal!
Old Aug 16, 2002 | 09:14 AM
Post
I always keep my engine bay clean but the paint looks dull. I have tried to wax it before but all i was left was a red rag were all the paint was comming off.
Old Aug 16, 2002 | 09:24 AM
MikeLS's Avatar
Lightbulb
Well, I suppose that makes sense. The paint in those areas generally is not the same quality as the outside of the car. I don't believe they spray any clear coat in those areas either, which is why you were probably seeing the paint come off with a wax. With a cleaner/wax you'll definitely see some pigment coming off of a nonclear-coated surface. Unfortunately, it's almost impossible to make the engine area factory paint look as good as the rest of the car. Have you tried some kind of temporary gloss enhancer spray? I doubt it would do to much good if the wax didn't make much difference though. Just a thought...
[This message has been edited by MikeLS (edited August 16, 2002).]
Old Aug 16, 2002 | 10:34 AM
97BlackT\A's Avatar
Post
Mike is right, the underhood paint is of the single stage, semi-gloss variety.
It's usually not very thick, either, so use caution when working with it.
I wonder if Zaino or Klasse would layer well enough to work under there??
Jeff
Old Aug 16, 2002 | 10:59 AM
blkZ28Conv's Avatar
Post
If this cleaning and shine production is for a car to be shown (car show), only rejuveniate gloss to the original level. Anything beyond OEM sheen will lead to point deductions. If for personal gratification a high silicone non-cleaning based pure carnuaba may add some gloss. Zaino (Z2) because of its glossiness may also add some increased
sheen.
95 Triple Blk Z28 Convertible - "garage queen"
[This message has been edited by blkZ28Conv (edited August 16, 2002).]
Queens94z28
Dec 20, 2014 09:11 PM
ModdedNerd
Dec 14, 2014 10:28 AM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
formula218
Dec 2, 2014 04:27 PM
