How long can Mixed ZFX and Z5 be stored??
For optimum results, use ZFX within 6 hours of mixing.
The ZFX™ mixing bottles cannot be reused if the polish remains in the bottle for more than 12 hours. After 12 hours, it is not possible to remove the ZFX™ accelerator from the mixing bottles. Throw the mixing bottle and any unused polish contents away after 12 hours.
Try to only mix as much as you think you will use up completely within 6 hours. You can do up to 3 coats.
If you let the bottles soak with rubbing alcohol, they will eventually come clean. I've left them without cleaning for a couple of days after a Zaino Day with our club. But they are MUCH easier to clean after first using them.
After the 6 hours the enzymes start to progressively break down again, by 24 hours it is just regular polish again. That is why it is best to use before 6 hours to get the full benefit from the ZFX. Mix up only what you have time to apply, you can always much up more.
Victor Lamb
Aug 26, 2017 02:52 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
