High Temp Powder Coat Needed for Intake?
Old Apr 16, 2009 | 05:16 PM
Hal Fisher's Avatar
I know if your just painting an intake you'd use high temp paint but I want it powder coated. Is high temp powder coat really needed for the intake? Normal powder coat is good for a little over 300f. I noticed there is a rubber grument (sp?) on the intake that seems fine with the temp it normally reaches. They stated this grument had to come off for the oven process of powder coating. So I figure if the rubber can not handle the oven but the powder coat can than it must be OK to just use normal temp powder coat. Anyone have experience with normal temp powder coat on the intake?
Old Apr 18, 2009 | 06:00 PM
Mr.Whitey's Avatar
Most powders that I used would be cured around 400deg., so unless you plan on lighting your car on fire you'll be fine using normal powder.
Old Apr 20, 2009 | 02:30 AM
Hal Fisher's Avatar
I noticed a few on ebay just using the 400 temp as well.
I reasoned that low temp pc would be OK becaue they were making me take the rubber gurment out of the intake so it wouldn't get burned. That proved to me that the intake never gets as hot as the powder coating process so it should be OK.
Hal
Old May 19, 2009 | 10:50 PM
hairbear21's Avatar
Mine has been powder coated in standard powder and it's fine. I've had it on for over a year, and it still looks great.
Old May 27, 2009 | 11:05 AM
n2omike's Avatar
heres mine with normal powder.
This is a very good shop. My buddy owns it but before he did I used them.
http://cfpowdercoating.com/
Old May 27, 2009 | 02:53 PM
hairbear21's Avatar
NICE!
I wish that I had done mine in something other than black, you can hardly see mine.
This is definitely the perfect thing to do to your intake when you're doing the lovely intake leak repair too.
LT14LIFE
Feb 9, 2015 09:35 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
Jul 4, 2005 05:00 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
