Rear Brake Calipers
Rear Brake Calipers
Need both sides, the bleed screws on mine wont break open. Tried everything, they are rounded off now so want to replace. Let me know if u have any spares. The bleed screws MUST be able to open and the caliper has to be fully functional, thank you.
Re: Rear Brake Calipers
if there is a will, there is a way.. those bleed screws will either COME OUT or they will BREAK, if they are rounded off, then grind some grooves on them and put a pair of vice grips as tight as they can go on them and get them off......
if not, then i have some somewhere id sell you that are in perfect working order..
Jarret, i will let u know if this doesnt work and i will just by em, thanks
CGM2010CAMARO
Apr 7, 2015 07:44 PM
trefidy
Jul 26, 2002 03:40 PM
