High Capacity/High Flow Radiator
Old Jun 1, 2005 | 03:20 PM
Gio93z's Avatar
Looking for a high capacity or high flow radiator for automatic 93 z28 camaro - getting 383 motor and wouldnt mind a better coolant flow - any suggestions on where to get one ... looking for something reasonable - i am expecting to pay over 200 for it but cant find a place that sells what i need......thanks
Old Jun 2, 2005 | 10:13 AM
mitchntx's Avatar
Re: High Capacity/High Flow Radiator
You won't find a direct replacement like you describe for under $500.
I found a Howe all aluminum radiator that was considered a direct replacement for an LT1 equipped F-Body and it was closer to $700. It was for a manual trans ...
The problem is reverse flow cooling, placement of radiator hose connection, their size, and the 2 other connections from the TB and water pump (oil cooler option).
Just not a lot of call for this type of thing ...
HectorM52
Jun 23, 2016 08:42 PM
TitoPR221
May 26, 2015 12:20 AM
Jan 23, 2015 01:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
