Pacific Alaska, California, Hawaii, Oregon and Washington
You knew this post was coming.
Old Aug 27, 2003 | 10:12 PM
NorthernSS's Avatar
I did dyno only 256hp and am lookin for ways to improve that without diving into the engine. That WILL come later. Anything helps. Any suggestions? Do you know of anyone that sells SLP parts? Anywhere either than a dealer? Thanks.
Old Aug 27, 2003 | 10:32 PM
1quickgt's Avatar
hey amn i just saw the video that green camaro was yours right? nice ride sounded really good
Old Aug 27, 2003 | 10:57 PM
Pandamonkey's Avatar
Damn.
Makes me sad to hear that........
That means that I may be somewhere around that number also.
I guess it's good enough to take care of 99% of traffic out there.......
Old Aug 27, 2003 | 11:00 PM
Draco's Avatar
intake, exhaust, headers, electric water pump, roller rockers, and tuning should get you to around 300 rwhp.
oldschool's Avatar
first get it running properly (do a tune up)
next...
get some headers, electric water pump, K&N (cut out baffles) roller rockers w/better springs, maybe a new cold air unit (ss ones suck)
after that...
get a bigger cam (cc305 or hot cam) along with everything that goes with it, and some ported heads, comp type R-lifters, molly push rods etc....
= $$$ BLING $$$
For an Auto I'd go all bolt-ones + hi-stall converter + deeper gears + M/T ET Steets and go mid 12's in the 1/4.
Old Aug 27, 2003 | 11:24 PM
NiteRider's Avatar
He already has headers ont hat thing, he should be in the 270 hp range. Just change your plugs and wires.
Old Aug 28, 2003 | 10:07 AM
NorthernSS's Avatar
I got SLP headers, Loudmouth, MSD wires, Bosh plugs, K&N, LT4 KM. I know the wires are crap. I've had alot of people say not to do the CAI and leave the ram air. I guess I should start with a couple of the cheap/free mods.
Old Aug 28, 2003 | 12:11 PM
Tw!tchb!tch's Avatar
Maybe atap it and see whats up . Something doesnt sound right . . . arent stock lt1's supposed to lay out 280 rwhp ish Did you tune after the long tube install . . . maybe you have a bad cat
Old Aug 28, 2003 | 12:46 PM
JD30thZ28's Avatar
Stock LT1's range from 235-250, i say check the plugs/wires and yank the cat. Change the induction.
We got pretty much the same mods, less the induction, so you should be making the same amount as me at least. Also my run was with a bad MAF so I plan to put done more next time on the dyno. Should be making 280+ for sure.
Old Aug 28, 2003 | 02:54 PM
Muskys SS's Avatar
I would suggest changing your plugs and wires then convert to OBD1 so you can tune the car. With only headers and a tune I'm trapping 105mph which is around 290rwhp.
Old Aug 28, 2003 | 07:39 PM
IPISSONFORDS's Avatar
Re: You knew this post was coming.
My stock muffler had a hole rusted in it so I replaced it with a Magnaflow catback exhaust, put it on Harvey's Dyno and pulled 273rwhp. Your car is ram air your number might be off by 20. Modify your ecu program.
Old Aug 28, 2003 | 10:54 PM
NorthernSS's Avatar
Gentlemen I realize now that any mods that cost any decent amount will have to wait. I have priorities like tires, a winter car/truck and others. God Damn have to be responsible and ****. Anyways, I appreciate the suggestions and i will definately follow up lots. Thanks.
jackpawt883
Jun 14, 2015 09:59 AM
sherwinZ28
Jun 6, 2015 08:48 PM
