Update: Suspension Problems Fixed
Re: Update: Suspension Problems Fixed
Originally Posted by JD30thZ28
Sorry boys, i am running tommorow on my dr's
Matt bring your laptop and cables I need to make some adjustments to my tune. Thanks
I still plan to use those 15" Pro Stars...I bought a new set of the Mickey Thompson DRs in the 26x11.5 size.
I just don't have the time right now with work being so busy and my grinder is in North Van. My next 2 weekends are tied up with work.
I'll get to it but I figure it will be early June before I have all my gear ready.
Oldschool, we have the exact same car and the exact same ET & MPH
MY best ET 12.61 & my best MPH 109. What color is your car, mine is silver and it is 6 speed WS6 / TA.
what mods you got??
Every bolt-on you can do. No internal work IE: No heads or cam (stock internals) The 12.61 number was before I did the PCM tune and the cut-out. I'm pretty sure the car has at least a 12.40 in it. I'm betting the MPH will be close if not 110 plus. I have also put all the BMR tubular Upper & lower and K-member, plus the Wilwood big brake setup, so I think I have shaved another 100 lbs. off the front of the car.
slothgrant
Aug 22, 2002 03:01 PM
