Pacific Alaska, California, Hawaii, Oregon and Washington
She's Back!!!!!!!!!!!!!!!
Old May 14, 2003 | 09:04 PM
Muskys SS's Avatar
Talking She's Back!!!!!!!!!!!!!!!
Well after countless hours of trying to figure out my missfire problem after the header install, it is finally over!!!!!!
I was able to get it on the scope today and the #5 cylinder was acting up. First off I changed the Plug wire but that didn't do anything. So I went and bought another plug and sure enough it's fixed. I'm so pissed that one of my new plugs was no good!!! It cost me so much time
I'm still experiencing a bit of missfire below 1500rpm when I give a lot of throttle, but above that everything feels good. Does anybody have an idea why the car is doing this??? Could it be knock????
Old May 15, 2003 | 11:43 AM
GreenZ28in503's Avatar
I replaced my coil and my ~1500 rpm miss went away.
Old May 15, 2003 | 11:45 AM
JD30thZ28's Avatar
Congrats, I had the same issues after my SLP header install they are cursed........
I would guess EGR for your stumble, my problem ended up being a bad O2 although the car still doesn't feel 100% the dyno will tell for sure on the 25th
Old May 15, 2003 | 11:48 AM
ollie-99's Avatar
maybe its ur Opti?
didnt u recently havea problem w/ your water pump?
Old May 15, 2003 | 02:21 PM
Muskys SS's Avatar
Well I spoke too soon. The car is acting up again.
It runs better, but it still missfires
Old May 15, 2003 | 02:24 PM
JD30thZ28's Avatar
Check:
EGR
Coil Wire
O2's
MAF
Wires
Plugs
Opti
Get someone to scan your car
Old May 15, 2003 | 05:54 PM
NiteRider's Avatar
coil is high rpm stumble, probably your egr.
Old May 15, 2003 | 05:55 PM
bunker's Avatar
dirty coil end is ussually a stumble, bad coil is ussually a dead coil.
Old May 15, 2003 | 08:00 PM
Muskys SS's Avatar
I removed my egr
Old May 18, 2003 | 05:35 AM
bunker's Avatar
get that opti in there man, damb!
rideordie
Nov 5, 2019 04:52 PM
dgPltt
Feb 11, 2015 07:04 AM
Jan 23, 2015 01:13 PM
warmeck
Jan 20, 2015 10:29 PM
