Pacific Alaska, California, Hawaii, Oregon and Washington
Progress????Dead stop
Old Mar 23, 2003 | 09:09 PM
  #16
Draco's Avatar
Originally posted by 97TA-WS6-Con
We checked the wires going to the injectors. Everything is fine.
At this pioint we are speculating the ECU is at fault OR the stock PCM.
could the injectors themselves be not working? have you tried repositioning the injectors on the fuel raile to see if they work in different spots? its a longshot but give it a try.
Old Mar 23, 2003 | 09:16 PM
  #17
bunker's Avatar
splice into the injectors negative terminal & do a straight ground see if that makes it work.
Old Mar 23, 2003 | 09:59 PM
  #18
zturbo's Avatar
Reason I asked if you upgraded the wires is I have seen a few people who have had to upgrade their injector harness for big injectors (thought i heard you had 8* lb injectors.)
As for splicing into the harness to see if they are working I would rather get an injector tester (plugs into the harness and has a light that goes on and says if it is working or not. Usually costs about 70 bucks and up..
I have heard of a few people having problems with their ecu from fast and it only producing fuel for 6 cyl but I do not know if that is cause they had a grand national tune in there or something diff.
If you need to try out another set of large injectors i have a few sets. As well as some smaller 28's
Victor Lamb
Aug 26, 2017 02:52 PM
Feffman
Oct 9, 2015 05:42 AM
Feffman
Jul 2, 2015 06:52 AM
andrewcapps82
May 19, 2015 10:11 PM
BLK1997Z28
May 2, 2015 01:26 PM
