Pacific Alaska, California, Hawaii, Oregon and Washington
Pics of my new Cold Air Intake
Old Feb 5, 2003 | 02:44 AM
  #16
BennyBoy's Avatar
Black absorbs heat... will heatsoak be a concern? If the TB bypass is supposed to be good for a few hp, then maybe making the CAI tube a brighter or shinier color would help?
Old Feb 5, 2003 | 03:57 AM
  #17
sideways_Into_3rd's Avatar
fine, i'll get it ceramic coated then
redi - strip charges $150 for a set of headers .. i doubt they'd charge much for a small CAI
Old Feb 5, 2003 | 08:19 AM
  #18
silicuda's Avatar
Benny: K&N FIPK is black, does that mean it absorbs heat???
Old Feb 5, 2003 | 09:20 AM
  #19
OneFlyn95z28's Avatar
No time to go into it right now but black does NOT "Absorb" heat
On that same note the velocity of the air moving through there will make any color fine reguardless
Old Feb 5, 2003 | 09:31 AM
  #20
silicuda's Avatar
Thank you for clearing that up OneFlyn95z28
Old Feb 5, 2003 | 11:00 AM
  #21
the color of the material only determines its properties regarding to eflective heat .. such as UV rays (sunshine) or other sources of heat that are beingreflected from a source, not the heat thats in the air... so a black piece Vs a shiney piece, both absorb the same heat inside an engine compartment ... but if u put them under the sun, the black one will get MUCH hotter
the idea for having it ceramic coated was because the ceramic coating will resist absorbing ANY heat under the hood
Old Feb 5, 2003 | 11:34 AM
  #22
94Zman's Avatar
Old Feb 5, 2003 | 11:49 AM
  #23
BennyBoy's Avatar
Yes, but it is plastic. Plastic doesn't conduct heat as well as metal.
Sideways, I think that pipe would look good done up in a ceramic coating.
Old Feb 5, 2003 | 11:51 AM
  #24
silicuda's Avatar
I bet it would cost a fortune to have it coated in ceramic..
Old Feb 5, 2003 | 12:35 PM
  #25
bunker's Avatar
I like it quite a bit, is it alluminum? If so sand it with fine sand paper, than NVR DULL that thing it'll look killer.
30thZ4C
Dec 26, 2014 05:09 PM
thenewkid
Nov 27, 2014 09:41 AM
94z28jbw
Sep 8, 2002 03:22 PM
ezcheeze15
Aug 26, 2002 01:28 PM
slothgrant
Aug 22, 2002 03:01 PM
