Pacific Alaska, California, Hawaii, Oregon and Washington
My car is officially F*CKED!
Old Aug 14, 2003 | 12:18 PM
  #31
grygst76's Avatar
Originally posted by bunker
There is spark again, id on't ahve an opti I just have 8 coils, each per cylinder, new wire/plug/coil.
How do you know you have spark? Did you disconnect at the plug while running on a lift of some sort and rev it a few times? If it is always that one cylinder bad coil or weak spark is the only culprit. cracked head/bent valve/pushrod would not make the cylinder fill with fuel but a leaky injector/no spark/weak spark can cause unsurpassed problems. basics my friend basics.
Old Aug 14, 2003 | 05:35 PM
  #32
bunker's Avatar
Ok there is spark, bent valve/weak rings will cause compression loss which inturn results in an incomplete burn, I know what you mean, I'm tried of it, I also asked for a coil a can borrow with no luck but thus far it looks like there is spark just bad compression aswell, I'll try another coil, trying to find out just by swapping coils will take time & too much effort at this point since I"m so sick of this thing, Hey Chris can I borrow your coil for 1 day please ???
Old Aug 14, 2003 | 07:57 PM
  #33
93formula's Avatar
try switching plug wires around. could be the taylor wires.
Jazsun
Dec 29, 2014 12:14 PM
mark0006
Dec 25, 2014 09:50 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
