Pacific Alaska, California, Hawaii, Oregon and Washington
to lower my car is it good to?
Old Feb 10, 2003 | 01:58 AM
  #16
Muskys SS's Avatar
Originally posted by Draco
Whoa there Nelly. for maximum drop, the sportline kit is good however the spring rates are far too low for decent handling. The pro-kit is actually better for handling then the sportlines when matched with proper shocks. As far as handling goes the pro-kit ain't bad, but I wouldn't call them the best until we know what his suspension goals and reasons are.
There are other kits out there for those wanting even better performance. even with 600+ lb/inch springs on the front the ride isn't that bad... and there are a couple of coil sets out there with spring rates in that ballpark.
The first thing you need to ask yourself is what you want to do with your car (autocros, road racing, drag racing, pure street, show, or some combination).
The second thing is to decide how much to spend. A fully adjustable full coil over setup with matched swaybars, panhard rod, control arms, and bushings will offer the most potential but at the highest cost.
You've got it backwards there Craig.
The sportlines are the lower springs with higher spring rate...
Just thought I'd clear that up.
PS
I've already called payams sportlines...
Old Feb 10, 2003 | 02:08 AM
  #17
ls1_bc's Avatar
Thumbs up
Originally posted by ls1_bc
Hi kal2k
For what it's worth I've been told that as a rough rule of thumb for every inch the spring is shorter than stock it should be at least 20% stiffer.So for a spring 2" shorter should be aprox 40% stiffer. So the guys are correct cutting coils is just not a good idea.
Just my $0.02 worth.
PS. If you want to set your car up to handle as good as it looks go over to LS1.com and read some of the posts in the Autocross forum.
PSS. That's assuming that you have already read our fine Autocross forum here on our very own CamaroZ28.com board
Old Feb 10, 2003 | 02:16 AM
  #18
NiteRider's Avatar
I had to "adjust" my rear springs so that the car sits nicer. take a look at the pic in my sig.
Old Feb 10, 2003 | 09:08 AM
  #19
Tw!tchb!tch's Avatar
You can have em for 220 $ . . . I paid WAY more . . . . I think 208 or 210 usd plus shipping etc . There on my car know so let me know if you want them and Ill have order my Koni's and coilover setup asap because it has to dropship out of the us and there going to bang me up the *** with shipping . We can do the swap at my work , we have everything there , spring compressor , air tools etc . . . .can do em both at the same time .
Dave
Old Feb 10, 2003 | 11:00 AM
  #20
kal2k's Avatar
sorry guys me and mike have already made plans, thanks though fro trying to make a sale , i am going to buy some new lowering springs with the advice of mike
Old Feb 10, 2003 | 11:20 AM
  #21
Draco's Avatar
PS
I beg to differ.
Please see the following link:
http://www.socal-fbodies.org/resrc.html
The sportlines not only have more drop, they have lower spring rates. This makes them much more likely to bottom out (especially with stock decarbon shocks), and they will have less roll resistance
Old Feb 10, 2003 | 11:27 AM
  #22
sleeperZragtop's Avatar
...Kal..Twitch's springs are pretty much new..and he never races his car ...so if you choose to buy the sportlines that would be fine...but Craig is right they will bottom out..then again they will look sweet...really think about this, I've heard some people complain about the results...
Mike
Old Feb 10, 2003 | 11:33 AM
  #23
Draco's Avatar
Hi kal2k
Actually, when you cut springs their spring rate (and thus stiffness) increases. That means you can cut stock springs, you just have to make sure you don't cut so much that the spring starts bottom out. In addition the stock shocks may not be able to handle the added stiffness. For more information and a spring rate calculator, please see:
http://faq.f650.com/FAQs/SpringRateFAQ.html
Old Feb 10, 2003 | 11:37 AM
  #24
Muskys SS's Avatar
I beg to differ.
Eibach themselves say that the sportlines are the high performance spring....http://www.eibach.com/index1.htm
The pro kits are designed for a balance of handling and road manners.
The sportline have increased spring rate over the pro kit for handling.
http://www.tirerack.com/suspension/t...betterbest.htm
I've been in cars with pro kits and sportlines, and I must say the pro-kits have near stock ride feel until you get into the twisties. They are very progressive. my friends Supercoupe feels like a limo until you drive it hard.
The sportlines on the other hand are very firm and give the car a racelike feel
Old Feb 10, 2003 | 11:54 AM
  #25
Draco's Avatar
Maybe the supercoupe versions are setup differently....
The problem with these comparisons is that a car's handling is about much more then the springs used. Shocks, swaybars, bushings, control arms, chassis stiffness, camber control, weight distribution, rear suspension/driveline style (3-link, 4-link, axle, IRS, etc.) and tires all play a role in determing a car's overall handling prowess. And even then a setup tuned for autoX may not be optimal for a Road Race.
In the reading I have done on the autoX forums here and on LS1.com, most people agree that the Sportlines are simply too soft for F-bodies. However I am sure that if you wanted to you could match the other suspension components and make the Sportlines work well.
Old Feb 10, 2003 | 12:46 PM
  #26
1999V6's Avatar
Twitch....where did you get your BMR adj pan hard rod and how much?? Where did you get it installed and for how much? Ever since I lowered my car I've got that "fbody lean" that I wanna fix. Thanks.
Old Feb 10, 2003 | 01:48 PM
  #27
sideways_Into_3rd's Avatar
i've personally NEVER EVER bottomed out (WITH LONGTUBES) on the eibach sportlines .. considering im running 4 year old stock decarbons that have been dead for a LOOOONG TIME !!
but either way .. im selling my springs for $150 ... and musky has already called them ..
Old Feb 10, 2003 | 04:57 PM
  #28
I got one for Doc and myself..through Stealth Performance in Portland....120.00 shipped..let me know and I can get you one..
..it only take's minutes to install...
Old Feb 10, 2003 | 05:32 PM
  #29
LuCiFeR97Z28's Avatar
I had the Pro-Kit installed in my Z28 for 2 months before getting the Sportlines. The Pro-Kit was definitely more aggressive...the ride height was about 1.25" lower than stock. With the Sportlines, I had more performance over stock, but not nearly as much as the Pro-kit. The reason why I changed to the Sportlines was becuase I needed a bigger drop to complement the 18" Vette rims and the GFX kit .
Damn I miss my car .
Old Feb 10, 2003 | 05:40 PM
  #30
Aly..any pics of that old beast...very curious
