Pacific Alaska, California, Hawaii, Oregon and Washington
K-member and control arms
Old Mar 26, 2004 | 10:32 AM
97TA-WS6-Con's Avatar
Well I have decided to get a K-member and control arms.
Any one local have some they want to sell before I order them?
Old Mar 26, 2004 | 09:24 PM
OneFlyn95z28's Avatar
Definatly get the BMRs
Old Mar 26, 2004 | 10:02 PM
93formula's Avatar
are you gonna AX the car? or attempt to daily drive it? if so i would read this thread before you get em, there ment for the track
http://mtfba.org/rrforum/index.php?act=ST&f=3&t=816&
Old Mar 26, 2004 | 10:19 PM
Mikey 97Z M6's Avatar
Don't believe everything you read on the internet. The forces loaded from the bottom of the car when jacking it, are not even close to the forces applied while driving. A 1" tubular bar may bend under a horizontal force of 200 lbs, but turn the bar to a compressive load and now can possibly withstand 3000 lbs of load.
All the mounts for the K-member are toward the outside of the piece where the A-arms mount. The only thing the center portion does is hold the engine basically.
Mike
Old Mar 26, 2004 | 10:27 PM
93formula's Avatar
well ill believe the AX/road race guys. and ive seen proof of it not protecting on mike pubiclover's broken trashed oilpan.
Old Mar 27, 2004 | 10:43 AM
Tw!tchb!tch's Avatar
Im 100 % with Roy on this one , nobody will touch a Bmr k member for road racing because it looks like it will fold in two . LGM has one coming out thats porpose built to be used hard .
Great drag piece though
Old Mar 27, 2004 | 11:13 AM
Actually you guys need to go back to your engineering classes
The bar across the bottom has one purpose and one purpose only...and protecting the pan is not it Neither is it a jacking point.
I have been sceptical for years about them but if you look into it ALL the loads are at the mounting points save for the Steering rack. THE BMR has the best built in features and if you feel it is not strong enough you can add bars at any time.
It is up to you guys and I under stand but you can ask anyone who knows me I do not like the Idea of any of them but they are becoming a neccasary Evil for weight reduction.
Here is the BMR with built in engine mounts
http://www.bmrfabrication.com/K-Members/km002.jpg
I could not find the LG part. I CAN tell you I have seen the LG Lower A arms bend under racing conditions
Good luck and choose as you may
Old Mar 27, 2004 | 11:33 AM
bunker's Avatar
Without looking at it I can't offer my Engineering experties , but from what I can remember there didn't seem to be any consentrated stress areas that would be dirrectly effecting any of the mounting points on the K-member, correct me if I'm wrong but thats what I can remember from seeing it on Mike's LS1.
Matt.
Old Mar 27, 2004 | 11:37 AM
I guess weight reduction and access to the motor are the only two benefits.
I'm not a serious racer though.
I wonder if the $1000 is worth it?
Old Mar 27, 2004 | 11:49 AM
bunker's Avatar
I would keep my money as I did, I was going to go with it but the amount of driving I'm doing I don't want my motor looking like it got dragged on pavement.
Old Mar 27, 2004 | 11:50 AM
I guess I should have clarified. In reference to the link above, the guy stated that the BMR unit would eventually break. I seriously doubt that it will break under normal suspension movement. Now jacking up the car at the point mentioned may take it's toll on the welds if it in fact is bending as much as he said, but then again, I don't believe everything I read.
MIke
Old Mar 27, 2004 | 12:45 PM
SBainsTA's Avatar
$1000 bucks for a kmember!!!!????? or is that with the a-arms? If you want to take a look at one Shaun, Give me a call. I'll be putting one in soon and currently it is sitting on a futon.
Old Mar 28, 2004 | 11:15 AM
bunker's Avatar
publicovers oil pan got trashed because his car was insanely low .. had nothing to do with his K member
Old Mar 28, 2004 | 12:10 PM
Being very low and getting 12 inches of air at 72nd and 152nd contributed to that.
Way to go Bo Duke
Old Mar 28, 2004 | 12:13 PM
Way to go Bo Duke
That made me laugh....
Mike
