Pacific Alaska, California, Hawaii, Oregon and Washington
Inexpensive high flow cats
Old Oct 15, 2003 | 09:41 PM
  #16
NiteRider's Avatar
Originally posted by 93formula
the cheapest cats with the highest flow would be stock ls1 cats, only one company out flows them.
Would that be random tech?
Old Oct 15, 2003 | 10:10 PM
  #17
95wagon's Avatar
Armen, I have heard and smelled your car. Methinks you will not be simply breezing through Aircare.
As for Randoom tech cats I have personally seen less than stellar results with them.
The Walker 151 series work reasonably well although they have come up with better cats that at this point are unavailable.
One thing to note, just because your O2s look good on Datamaster at idle, that does not mean you are actually at the correct mixture.
Because of overlap you have free oxygen in the exhaust that the sensor looks at. The end result is the mixture ends up being rich at idle even though the PCM thinks it is doing a fine job.
Let me know if you are in the market for cats and I will get you prices on stuff I can get.
Regards, Gerry
Old Oct 15, 2003 | 10:17 PM
  #18
NiteRider's Avatar
Thanks Gerry, I will let you know when the time comes. As for aircare yes i'm thinking it will be more then a few trips to the rollers. To bad the only readings they give are emissions.
Old Oct 16, 2003 | 02:16 AM
  #19
sideways_Into_3rd's Avatar
IMO anyone with a "large" cam needs to tune in closed loop for idle and emissions ... for the exact reason gerry mentioned . ur O2s are useless cuz they get fooled by the overlap ...
just turn those things off at idle, tune ur mixture in the open loop tables, slap some 315s on the back and go do the idle test (some places wont put it on the rollers with u have wide *** bling blings on the back) .. like i did with rickerby's car when i took it thru aircare
Old Oct 16, 2003 | 02:49 AM
  #20
95wagon's Avatar
Yeah , the peasants have been using studded snows for the same purpose.
I assume you meant "open loop"?
Old Oct 16, 2003 | 04:00 PM
  #21
NiteRider's Avatar
Woulden't a larger cam with more overlap, i.e. 112 lsa, be worse for a idle test?
Old Oct 16, 2003 | 04:03 PM
  #22
yah but u gonna have to pass the idle test ANYWAY .. so if u only do the idle test u only have to worry about tuning for one thing, aka the idle mixture ... and not worry about the rest of ur tune
Old Oct 16, 2003 | 04:28 PM
  #23
NiteRider's Avatar
This is true, although i'd like to get 2 year pass and it's defiantly worth a try or even many tries.
TitoPR221
May 26, 2015 12:20 AM
alex5366
Mar 8, 2015 11:32 AM
jeff94z28
Sep 11, 2002 02:01 PM
blue89iroc
Jul 26, 2002 04:56 PM
blue89iroc
Jul 18, 2002 03:35 PM
