Pacific Alaska, California, Hawaii, Oregon and Washington
Hmmmmm *rubs chin*
Old Mar 8, 2006 | 11:08 PM
97TA-WS6-Con's Avatar
Hmmmmm *rubs chin*
I have a four-door vette in the driveway. I think a four-door viper might be interesting.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
We'll see.
Old Mar 9, 2006 | 12:03 AM
bunker's Avatar
Re: Hmmmmm *rubs chin*
Very cool
Old Mar 9, 2006 | 01:04 AM
sideways_Into_3rd's Avatar
hows the 4 jackstand TA ?
Old Mar 9, 2006 | 01:21 AM
bunker's Avatar
I heard it's had the lift job for quite some time, will probably clear the terrain better then the Dodge, the Dodge has a slight lowering job in comparisson
Jk.
Old Mar 9, 2006 | 02:45 AM
talos's Avatar
I heard the srt-10 was actually quite slow for what it is...
Old Mar 9, 2006 | 03:19 PM
....actually, been on four wheels for some time.
I got the blower re-installed in September and ran it around the block a few times. Motor and blower are fine at this point.
BUT
having a problem with the high speed fans. Simply cannot figure out how to get them to come on or why they aren't coming on. Also failed Air Care in a huge way.
Hopefully this Saturday the car goes to Rrashpaul's shop to see if he can fix the fans and also tune for air care.
Then I have to get an inlet pipe made for the air filter side of the blower.
HOPEFULLY, insure it for the whole summer.
Old Mar 9, 2006 | 04:23 PM
bunker's Avatar
Nice! I can't see the fans being a problem at all, if all checks out/Relay, are those fans aftermarket? May need a higher AMP rated relay, I can't see it being a big problem to find.
Hope she passes emissions, note that if your'e using the FLP cats, I must say, they are not the best cats on the plannet LOL, and they do go bad just sitting there, I suggest getting new cats.
Old Mar 9, 2006 | 04:42 PM
No just stock fans. I dunno, electrics is not my thing.
Old Mar 9, 2006 | 05:35 PM
Rybar's Avatar
Sean, I know a guy who knows his sh*t about wiring. PM if you want his number, I'm sure he can figure out your problems.
Old Mar 9, 2006 | 05:41 PM
bunker's Avatar
I think I know who your talking about Rybar yeah Sean I'd give him a try instead of a shop who will bill you through the nose and break something else LOL as it seems like is a reoccuring issue with your frequent visits
But as far as finding probs like this is simple basic electronics.
Old Mar 9, 2006 | 07:49 PM
just rig up a signal wire between the 2 relays, that way your high speed will kick in with your primary fan ..
as for aircare ... put your stock ECU back in with the program i made to make it pass last time
id be glad to make it pass again
Old Mar 10, 2006 | 02:49 AM
bunker's Avatar
I think he's looking for a proper fix for fans
However, aircare should not be a concern at all so long as your o2 is doing it's job properly and cats are good with your setup.
But something tells me the advise of the Young Ones will not be taken.
Old Mar 10, 2006 | 11:15 AM
Draco's Avatar
Hey Shaun did you pass the OBDII readiness tests at aircare? Not sure if your FAST system interferes with these tests - if it does you will have to revert back to your stock PCM during emissions testing.
Anyway my point is that come August when the current Aircare contract expires, they are most likely going to get rid of tailpipe sniffer tests for OBDII cars, and just check the readiness tests. You will pass as long as you dont have more then 2 readiness failures.
If you want to ensure the car for the summer you could just take the maximum 3-month permit now that you failed aircare, and wait for aircare to 'expire' in august.
Old Mar 10, 2006 | 04:22 PM
bunker's Avatar
I think that will only apply to 98+ cars.
Old Mar 10, 2006 | 07:26 PM
email sent
Thanks Ryan
