Pacific Alaska, California, Hawaii, Oregon and Washington
Getting closer
Old May 31, 2005 | 04:25 PM
  #31
JD30thZ28's Avatar
Re: Getting closer
Ok both of you have made valid points, now the true test will be in a few weeks when Shaun's get's out to the track and drops the clutch at 5,000rpm
Now Play Nice
Old May 31, 2005 | 04:34 PM
  #32
bunker's Avatar
Re: Getting closer
Yes, and I'm not arguing a lot of what Cory says, I'm just frustruated to see Shawn going through a 4th or 5th rebuild, thats why I want him to do something different this time around. The first time I"d say yeah let it be since they are soft moly rings etc.. But when all those times he had blow by, do it differently. But he and Cory have not, I'm not saying the rings will seat just like soft moly rings should, but they didn't last time so what makes you think they will this time?
Thats like tunning a car, getting no power and 9:1 A/F and saying, well the values are the same as the last time I was here or the same as the other guy with the same setup why should I do anything differently? Well just do it so later you're not thinking what you could have done differently.
Old May 31, 2005 | 04:37 PM
  #33
JD30thZ28's Avatar
Re: Getting closer
Matt go find my cam, springs and rockers this topic has died until Shaun goes for a 10sec slip
Old May 31, 2005 | 04:54 PM
  #34
97TA-WS6-Con's Avatar
Re: Getting closer
Matt
Although I do appreciate your good intentions, at the end of the day, Rash is there, right from the beginning. He has 100% of my confidance, and if things do not go right, he's there to address it and correct it ultimately. He has been EXTREMELY generous in giving me his time.
We shut the car down as soon as temps were even modestly above normal but we had to get the car UP to temp before we knew if there was even a problem.
As you know I have learnt a lot of things the hard way but.......
Its all good.
Old May 31, 2005 | 05:00 PM
  #35
bunker's Avatar
Re: Getting closer
You know what, I'm probably even posting here beause I'm not working today, normally I would ignore a post like this. You find your own cam! Already told you, actually here is a nice priced one:
http://web.camaross.com/forums/showt...&highlight=847
Old Jun 1, 2005 | 10:23 PM
  #36
OneFlyn95z28's Avatar
Re: Getting closer
Originally Posted by 97TA-WS6-Con
His exact phrase was "...not a problem with a roller cam. No need to "break" the engine in." Again, we was there from the start, the car did NOT overheat it just got hotter then it should have. The car was idling for a good 5 - 10 mins before the temps got to the 190 range. He was closely following the air fuel ratio and the car ran in the 13.5 - 14 range throughout.
Dang it has been a while big guy! Glad it is up and running. All seems to be in order and you have a good man there to give advise
I will shoot you a PM
Ellis
Speed Secrets
"The Secret to Reliable Performance!"
brothaslide
Jan 9, 2016 12:11 PM
guruerror
Jun 9, 2015 07:41 AM
R@mpage
Apr 20, 2015 10:02 AM
cmsmith
Mar 23, 2015 11:45 AM
MysticTeal 95 V6
East South Central
Mar 25, 2003 02:19 AM
