Pacific Alaska, California, Hawaii, Oregon and Washington
Car acting up!!
Old Jun 24, 2004 | 07:23 PM
ollie-99's Avatar
Thumbs down Car acting up!!
So i went and got gas and the damn thinlg wouldnt wanna start
so i tried a few times; sounded like only a few cylinders were running and would stall.. Finally i got her started and she aint running 100%
Dont know what it could be? Possibly the opti? i dunno its buggin me
so maybe matt or anyone else w/ knowledge if u got time; can u take a look @ her for me
It even stalled @ a red light and took me a few tries to get her goin again!
i think its either the wires or opti or its just a POS
lol
ok thanks!
-Ollie
Old Jun 24, 2004 | 07:42 PM
Camaro ChriSS's Avatar
I'm not too knowledgable about opti's, but that does sound like a ignition wiring problem. So I think you may be right. I would figure Matt or Roy might know better.
Old Jun 24, 2004 | 09:32 PM
1quickgt's Avatar
ahh amn pimp juce acting up again... i know what you need....ob this weeknd? oh ya
Old Jun 24, 2004 | 09:45 PM
Jeepoo's Avatar
First thing I would check is fuel pressure. My '96 did the same thing and the in tank pump puked. GM rates the life of the pump at between 80,000 and 100,000 km's. When my opti went it wouldn't run at all.
Jeepoo
Old Jun 25, 2004 | 12:19 AM
todd15's Avatar
check your coil and opti wires........mine u to stall at lights..then would be hard to start
Old Jun 25, 2004 | 12:28 AM
bunker's Avatar
Hey Jeepo update your sig
Old Jun 25, 2004 | 02:13 AM
93formula's Avatar
come by my house, drop off my rims and tires and lets go for a spin and see what it feels like. have you ran out of gas latley? could be opti or coil, but didnt you do the opti when you swaped the cam? how are your wires? my opti was pretty much dead when it did the things you describe but it can also be coil, or wires as well.
Old Jun 25, 2004 | 04:47 AM
ollie-99's Avatar
i actually ran outta gas the nite before and i did not replace my optic when i did my cam swap
when are u available tomorrrow?
thanks
Old Jun 25, 2004 | 08:02 AM
bunker's Avatar
Ohh please, get under that car & start wrenching away.
Old Jun 25, 2004 | 11:01 AM
Draco's Avatar
thanks
Running out of gas is bad for the pump (it can overheat). Does the pump prime when you turn the ignition to 'ON' without starting the car?
Definitely check fuel pressure first since you ran out of gas recently.
Old Jun 25, 2004 | 12:01 PM
bunker's Avatar
Its funny how some people run out of gas on a daily basis & some run out once & they're screwed LOL, look at Armen the Niterider, he runs out of gas everyday
Old Jun 25, 2004 | 04:20 PM
1999V6's Avatar
Sounds like a similar problem when my pump went out. Like the other post says, see if the pump primes when you put the key in.
I let mine sit for a bit, tryed to fire it up again and it seemed fine. While running, 20 mins later it stalled again. Car wouldn't turn on whatsoever. Tried a few hours later and it worked again, then stalled.
Sometimes if you stick a 2x4 on the tank and pound it with a hammer it can "wake" the pump up and start it. If it's the case time for a new one.
If that's not it and the car feels like it's not running on all cylinders, maybe it's something simple like a spark plug wire touching the engine block somewhere.
Old Jun 25, 2004 | 09:46 PM
93formula's Avatar
thanks
yeah could be the pump, you got a fuel pressure gauge with your nitrous? when it stalls how hard is it to start again? actually im on my way out right now give me a call later on.
Red Hawk 94
Mar 18, 2019 04:03 PM
Noenav
Mar 1, 2019 07:38 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Jazsun
Dec 29, 2014 12:14 PM
USAirman93
Nov 24, 2014 03:37 PM
