Help!
Old Aug 4, 2012 | 04:18 PM
pbrandt1744's Avatar
Help!
last night coming home from south florida, went though some rain and my camaro started acting up. first it acted like it ran out of gas and just died, i pulled off the road and it fired right back up. as i was driving i noticed the tach would be arractticly jumping RPMs, and it would start to miss and die, but it still would fire right back up. it seem to run ok in 5 gear and at 3000rpms. i made it home. but now the car wont start. check for spark at plugs with no avail. check fire from coil and nothing. i would hate to go buy a coil and it still not work. how do i test the coil to see if it is bad. could it be the pcm, distributor, or what. please help.
Old Aug 5, 2012 | 06:33 AM
TedH's Avatar
Re: Help!
Welcome to the board.
I wish I had a good answer. It would be helpful to know the year of the car...
On the LT1s the opti is fairly low (think waterpump/cam) so if you have an LT1 I would look there first (unfortunately). If it is the coil they are not that expensive and very easy to swap out. Try some various searches through the tech areas and I bet you can narrow down the list of suspects.
Old Aug 5, 2012 | 07:43 AM
brandons94lt1's Avatar
It might help to keep all of your answers in one place https://www.camaroz28.com/forums/sho...d.php?t=867944
Sounds like the opti.
